only one thing i'd change. see the black following all the way along the bottom but then at the front right where the fender and front bumper meet its not painted, I'd paint that little 4"x4" section black to keep the flow.
Thanks. Also those are escalade fender and door moldings/flares. The escalade bumpers are higher thats why theres a gap, but I plan to fiberglass a piece to fit right there.
If I had stock rims it would seem like a 4/6 drop. But since I had the 22's on the stock height was like 3 1/2 front and 2 1/2 back. Thats why I did the 3/2 drop and it looks like that. on flat ground, the back is higher, good thing because with all the subwoofers/box and all that, the back should drop 1/2 inch. The ride is smooth and it corners better not, no more weight shifts like before, well kinda but not as dramatic. I like it a lot =). I have to bend in the front fenders though, bc when I hit a dip and such, it rubs against my fender and its eating up my tires, but not to much, but I want to take care of it before it gets deeper. Oh yeah, and its all belltech suspension (shackles/spindles,coils, and shocks) and new control arm bushings which the mechanic hated me for bc it was a pain in the azz.
