**Klez's Install**
Username: Grebnereon
Post Number: 283
here it is....far from perfect. im still working on finishing it up.
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1849
nice. hows it sound?
Post Number: 1850
clean up some of the wires though.lol
Post Number: 284
edead vise2
Post Number: 285
AMP: Kicker kx1200.1, 1440 rms @ 1 ohm
SUBS: 12" Ascendant Audio Arsenals 750rms each
BOX: sealed, 2 chamber, 2.06 square Ft. NET per chamber (made myself ;])
Sound Deadening: EDEAD vise 2
sounded ok at first but once i put in that edead, it sounds awesome
Post Number: 286
i meant^^^FT cubed
Username: Basshead86
Try Google
Post Number: 7196
how do you like those Arsenals?
they sure do look nice.:-)
Username: Adddisorder
West palm, Florida
Post Number: 1295
looks good
Username: James1115
Ct
Post Number: 6936
look's nice bud how does it sound?
Username: Bayrent88
Ingleside, Texas USA
Post Number: 67
i would of faced the sub into the car though...but thats just me
Try Google
Post Number: 7219
sounds better/louder with the subs soundwaves resonating in the trunk:-)
Username: Bayrent88
Post Number: 69
oh...well thats why yall are gold members and i am just a lil o bronze member...yall know your shi t
Post Number: 1855
lol. thats not true for every car.
Try Google
Post Number: 7226
for most it is...unless the Trunk is sealed from the cabin. then it doesn't matter....
Username: James1115
Ct
Post Number: 6947
the more bass reflects off of before it hit's your ear the better it sounds. not always louder but you knock out more distortion if there is any.
Try Google
Post Number: 7229
thank you james....i shouldn't have said louder...obviously the closer to your ear the sub is...the louder it will be...
subs up port back seems to work best for suv's...
Username: Rob_preg
NE, Ohio United states
Post Number: 716
box placement can be mysterious at times. the best approach is to just try several placements and listen to which sounds best.
Username: James1115
Ct
Post Number: 6952
no prob man:-)
Username: James1115
Ct
Post Number: 6953
yup^^ it is different for every vehicle.
Username: Redliner
Wilmington, Ma
Post Number: 2708
i dont know why but to me it sounds better with subs facing in i dont like all the rattling in the back when its bouncing off everything maybe its just me.
Post Number: 287
yup ...they sound great,still havent fully let them go yet though...the gain still isnt set right....right now its at about a little over 1/2.....and ive only turned it up to 26 out of 34 a couple of times.and ive had it hooked up for about a month
Username: Matt12490
The biggity biggity BAY, California USA
Post Number: 1381
you shouldn't turn your gain up anymore. im pretty sure that headunit has 2v preouts and the gain goes from 340mv-10v so if its a little more than half its around 5v right now. you need to match that to your headunit (2v) your probably sending a clipped signal right now.
correct me if im wrong?
Post Number: 288
i havent noticed any clipping, you think i should get a new HU? didnt you have a sony HU like mine Matt F? could you explain to me how i would benefit from a HU with higher Volt preouts
Username: Matt12490
Post Number: 1385
clipping isnt really heard or hard to hear. i never had a sony hu, pioneer premier.. i dont know what the benifits of a hu w/ highter preouts maybe someone else does? im pretty sure that higher is definitely better tho.
Post Number: 290
yeah ive heard that too...but i dont know why
WASSUPUSA
Post Number: 6319
i'd face the subs in to the cabin too. box that big, it would be easy to seal the sides. you would gain alot more spl that way. if you don't believe me then just try it please. you'll know what i am talking about.
nice and clean looking install btw.
Username: Rovin
Trinidad & T...
Post Number: 9407
look good ,man !
normaly i too would say face backwards but from the pix it seems like the size of that box will block most or the waves resonating back into the car - but try facing it 4ward with the box far back as possible & let us know if the sound improves
only way 2 know is 2 actually try it ..........
Post Number: 297
alright...ill try it sometime...but its a real tight fit.....i had to raise my 6x9s just to fit a 14 1/2" box in there!!! i had to put it in through the back seat opening and its just really alkward. got to have atleast 2 people.
Post Number: 300
anybody
Post Number: 301
OK. I did it today : turned my box around and did a few other thing....eliminated some rattles etc. It is probably a few DBs louder...i havent filled in the space around the box yet to block off the trunk. will doing that make much of a difference?
BTLUSA
Post Number: 6402
yes. night and day difference.
BTLUSA
Post Number: 6403
i rolled up some rubber mats and squeezed it in between the box and the trunk and it made a big difference.
Post Number: 302
alright, ill do it tomorrow and post the results then. im not sure what to block it off with though.
