Installers 3
Username: Troy81
Tavernier, Fl Us
Post Number: 1232
where would you put your ground wire? on an 00 expedition
Username: Renegadesrun
Lafayette, IN US
Post Number: 360
Get a distribution block.
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 528
^See!That's one of the answers I posted jajaja?:-)I would place my ground wire anywhere there is metal with lots of pretty paint on it O_o.
Username: Naledge503
Portland, Oregon U.S.
Post Number: 354
whats your budget?
Username: Basshead86
Try Google
Post Number: 6997
eD....or A8000t if you can afford it...pffft
Username: James1115
Ct
Post Number: 6779
check near the flux capacitor normally it is good there:-)
WASSUPUSA
Post Number: 6232
hahaha james.
Username: Kyle_lowe
Post Number: 95
i have a picture of the flux capacitor taped to my dash. it adds 25horsepower easily.
Username: Adddisorder
West palm, Florida
Post Number: 1199
troy- anywhere you can, maybe where the seat belt attaches to the chasis
Username: Troy81
Tavernier, Fl Us
Post Number: 1237
ok, i just thought maybe some of you might have found a really good one or somethin and could enlighten me but i guess ill do it like i normally do
Username: Riskyb
Post Number: 251
I use the bolts that hold my seat to the seat frame.
