Lemme know...
Username: Mvplefty12
Pinellas, FLA America
Post Number: 96
Let me know if this sounds like a good budget sql setup.
15" Fi Q
Hifonics Bxi1206d
Eclipse EA4000 4 channel amp
Zapco i-6.2 6.5" components
Kinetik HC1400 battery
It's all going in a Honda Civic coupe... Thinking around 3.0ft cube box tuned to 32hz.
Thanks,
Drew
Post Number: 97
bump
Username: Kickdoor
Post Number: 69
you gotta wait more than 10 min to get an answer LOL
But thats a excellent set up for sure.
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1989
get a diff amp and are those the i-force comps??
i herd the lower zapcos arent good..
look at the focal polyglass upgraded $350
or the jl's XR
Username: Basshead86
Try Google
Post Number: 7009
i heard none of the Zapco comps are worth the money...i beleive Chauncey has heard them.
Post Number: 98
yea i would pick up the $350 dollar comps... but then it wouldnt really be a budget setup lol. Those zapco components can be had for 150. Any other suggestions for sub amp and components? Looking to spend $250-300 on the sub amp, and 200 on components.
Username: Alias747
MN
Post Number: 1446
You can get JL XR650-CSi components for around 200 on ebay. I think it would be worth it to check them out. The higher end JL comps. are well worth it I hear.
Try Google
Post Number: 7023
i would get some DLS Mag's for ~$250:-)
