Will my audio system kick?
Username: Manuelmatias
hi i am new in music, well reading something i have leared a little. here is what i goyt and please give me your opinion. i still haven't installed the music but i hope it will rock even a little. ok this is what i got and my plan:
my sub and mono amp for sub
1 12' pioneer 306dvc 1000w; 400rms
1 12' premier w126dvc 1000w; 400rms
powered up with a bazooka rsa800.1 d 800rms @2ohm
my speaker
1 pair infinity 6.25" 6010cs 90rms each speaker 270 watt each
1 pair mtx 6x9" TDX6902 100w each
1 pair of ev force 10" dont know the rating of it, is old but good but i dont know if my amp will do
kicker kx600.4 600 rms
i hape a cap of 2 farad, alpine 40x2 eq 9 band, pioneer xover, and sony mp3 radio 200-240 watt not sure.
can you give me your opinion if im good with that, thanks
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1520
do you have 2 different model subs?
yesh but they are rated at the same ohm , dvc, watt, rms all the same THING the only thing is the name AND I THING WHERE IT MADE
Post Number: 1522
do you have all of this stuff yet?
yes i have it , most of them installed les the 6.5 speaker,6x9, 1236dvc sub,kicker amp, and eq, then the rest is installed
Post Number: 1523
are your subs dual 2 or 4ohms
4ohm SVc 2 or 8 DCv
Post Number: 1527
what?
what is the duifference about the 306dvc and the 126 dvc? i thinks is only the name or am i wrong?
Post Number: 1528
are they dual 4 ohms or dual 2ohms
Username: Basshead86
Try Google
Post Number: 6721
same RMS on different subs means about as much as a Degree in UFC....lol
Post Number: 7
306dvc spec
Features
Size 12"
Woofer Cone Material Composite IMPP Cone using Interlaced Aramid Fiber
Woofer Cone Design Cone Reinforcement Arcs
Surround Wide Roll, Three-Layer Fiber Woven Radial
Voice Coil 4-Layer, Long Voice Coil
Voice Coil Wire Polyester-Imide Resin Coated
Voice Coil Bobbin 12 Slit Aluminum
Damper (Spider) Conex
Damper Ring Yes
Top Plate Standard
Projected Pole Yoke with Vented Pole
Magnet Construction Double Mass High-Power
Basket Design Stamped Basket with Magnet Cover
Gasket Molded
Wire Terminals Spring-Compression
Specifications
Watts MAX. Music Power 1000 Watts
Watts Nominal Power Handling 400 Watts
Frequency Response 18 ~ 500Hz
Sensitivity 89dB
Ohm Rating SVC:4, DVC: 2 or 8
Recommended Enclosure 0.85 ~ 1.75 Cubic Feet
Dimensions 13" x 7"
Mounting Depth 6-1/4"
Accessory Grill UD-G306 Available
126dvc spec
Features
Size 12"
Damper Ring Yes
Top Plate Standard
Gasket Molded
Wire Terminals Spring Compression
Specifications
Sensitivity 89dB
Dimensions 13" x 7"
Post Number: 8
its teh same thing i just bought it cuz i wan my sub box to say in one side Pioneer and the othe Premier (Pioneer Premier)
Try Google
Post Number: 6729
as long as you are ok with it Manny!:-)
Post Number: 9
will by the spec i thing it will work both the same way or am i wrong?
Post Number: 10
will by the spec i think it will work both the same way or am i wrong?
Try Google
Post Number: 6731
i would like to see sme Thiele/Small parameters, but they look identical build-wise...you should be fine:-)
they probably just slap the Premier logo on the other model and charge 1-1/2 the reg. price. lol
Post Number: 11
well i think is where is made, i know the premier is made in mexico but i dont remember where the pioneer was made cuz i dont have it with me
