Enclosure question
Username: G_money
Chitown, Illa USA
Post Number: 8
whats goin on everybody
can someone tell me what tuning a ported box high or low (hz) does or whats better to do. whats the difference in the way they will sound
4 cu ft box at 40 hz and 4 cu ft box at 28 hz
also, which one would be louder
can ya help me out.
Username: Frkkevin
Lake Worth, Texas US
Post Number: 953
the 28hz would get lower and not be as sloppy.. the box for 40hz would get louder when it peaks and at higher frequencies but would not hit the lows well at all... what are you trying to do?
Username: G_money
Chitown, Illa USA
Post Number: 10
whats up
im about to try and build a friend of mine a ported box for his 15" kicker cvr. He's putting it in a hynidai elantra. I havent had the time to measured his trunk but it looks like a 4 cu ft box will fit. but dont know what to tune it to he likes his music loud but to have clarity to. 60% spl 40% sql.
Username: Frkkevin
Post Number: 956
35hz with 64 square inches of port
Username: G_money
Chitown, Illa USA
Post Number: 11
cool bizness thanx
will it hit low and loud
Username: G_money
Chitown, Illa USA
Post Number: 12
how many cube inches
Username: Frkkevin
Post Number: 960
it will get fairly low.. if you want low low you'd have to tune to 28hz but then its not going to be more SPL oriented. 35hz will do him good. how many cube inches? 64? I'd build that box to be 4 cubic foot after displacement.. bigger box will make them lows lower... :-)
Username: G_money
Chitown, Illa USA
Post Number: 13
good lookin out kevin
i appriciate it alot thanx
