1 more quick question! before it gets DARK!!
Username: Extremesound1
Coventry, RI United states
Post Number: 235
the box is done all i need to do is wire it up
problem
i used the diagram from crutchfiled
my sub is a 2 OHM dvc.i want to hook it up to a 1 ohm...here it what ive done in blue and blackUploadknow do i take coil negative to amp and coil 2 positive,,,,or coil 1 positive to the amp and coil 2 negativge
Post Number: 237
or do i just take coil 1 negative and positive to the amp
quickly i want to hear this thing tonight
Username: Th3pwn3r
Chicago, Illinois U.S.A
Post Number: 303
I wish I could help but that drawing is soooo bad lol. I can't understand it at all.Just hook it up according to that rockford diagram.
Post Number: 238
but which is coil 1 and coil 2,,know what i mean.my kicker sub has a coil 1 positve and negative,so does coil 2..
Username: 420alldaylong
Post Number: 291
Positive to Posstive run off
Negative to Negative run off
Username: Th3pwn3r
Post Number: 305
Just wire all your positives together and all your negatives together and you'll be fine.Send a wire to from your amp's positive to each positive on the coils and send a negative from your amp to each negative on the coils.
Username: Oglejust
Post Number: 144
its all neg. to neg on amp and all pos. to pos on the amp.
Post Number: 293
The diagram explains it self.
Username: Makmillion
MN United States
Post Number: 626
Kicker subs have dots on one set of terminals.. the others have no dots.. that's how they seperate their coils visually
Username: Blainew
Post Number: 1610
u want the neg of one coil to the neg of the amp and the positive of the OTHER coild to the positive of the amp
