Disabling clifford clifford double star remote start
Username: Fabio1605
i have a g5 clifford with intellistart 4.
everytime i want to remote start the car ive got to arm it whilst in the car using clifford x2 double star. so the car knwos im in neutrol etc.
But in the manual it says that on automatics its not needed to prime the car first hand. all you need to do is press single star and the car will start
how would you go about making the alarm think the car is automatic or how would you go about making it so you dont need to prime it first.
(also is there any conseqnces etc)
