PLEASE HELP ME HURRY
Username: Blainew
Post Number: 1543
okay heres the deal.
my RE 12.1 is being weird haha. i have two hours to figure this out.
my head unit is a low end pioneer with a 2 volt RCA output
i have 2 diamond subs wired to 2 ohms, so the amp should be putting out 700 watts rms
on my head unit, since it is not a great one...i set the lows to -2, because any highher and my speakers rattle. there is no sub conrtol on the head unit
now heres the problem. with the gain all the way up, and the bass boost all the way up, the subs are not moving that much, but they are moving a little. i need to decide to send the amp back..or not..
the subs are not as loud as they are on my other amp, which is giving them like 450 rms total.
should i get a line driver to boost my voltage, would that help? do line drivers make the bass louder when you not gettin such a gread signal??? or do u think the amp is messed up.
oyea... one other thing, when i turn up the lows on my head unit to +6 and the volume up high....the bass is very loud, but it just seems weird bc i need to set everything to the max with the RE amp......
should i get a line driver???
Los Angeles, CA USA
Post Number: 5636
why would you have the bb and the gain all the way up? you are probably clipping your sub thats why its not moving that much. don't do that.
Username: Blainew
Post Number: 1544
they dont start to really move untill everything is up...
would a line driver help the bass...
or should i just return the amp
Los Angeles, CA USA
Post Number: 5637
you sure you checked all the amp settings? what are the specs of you re amp vs your older amp?
Username: Blainew
Post Number: 1546
re will do 700 with my subs and it is underated
the soundstrom will do 500with my subs and it is overated
and that 700 is moving the subs less than the 500
Username: Redliner
Wilmington, Ma
Post Number: 2541
check ur where ur rcas are polo just went through something like this make sure they are i the correct inputsand check the connections for solid connections
Username: Blainew
Post Number: 1547
checked
Username: Cenus
4, 2 0
Post Number: 2298
do you have a bass controler on it if so take it out, if you don't what are your filters set to on the amp, i had a similer problem, set the subsonic and LPF and it got a lot louder.
Username: Blainew
Post Number: 1548
tried taking bass booster out
set the low pass and subsonic at all dfiferent things
still im not gettin much power to my subs unless everythings at the max
does a line driver help with this....does a bigger input voltage from the rcas into an amp make the amp produce more power?
Username: Riskyb
Post Number: 189
I would have to say a line driver probably wouldn't help you. Check all the amp and headunit settings.
Other than this problemo how are the diamonds treating you? I'm glad you manned up and finally bought them. I love mine.
Username: Blainew
Post Number: 1550
haha i love them too.....but im so pissed about the amp..ive wanted this amp forever
Username: Cenus
4, 2 0
Post Number: 2299
hmmmm, well my HU only has like 2.6volts, and my gain is a little under 1/2 and everything is fine.
Username: Blainew
Post Number: 1551
i guess ill send it back to RE...
if they dont fix it for free....ill just get an ED NINE.1
Username: Riskyb
Post Number: 190
Was it two 10' d3s or 12' d3s?
Username: Blainew
Post Number: 1552
Username: Cadillacdb
Houston , TX
Post Number: 840
you know it could be ur ground.. i know you might not think this because ur soundstream works fine on the current ground but higher grade amps tend to be very picky about there grounds and they like a firm solid metal to bare chassis thick bolt ground with nuts on each side of the bolt both tightened so hard u nearly break ur wrest lol ... ive seen this happen fairly often with amps being given a poor ground... if that doesnt help at all then i would go ahead and send it in but not before exhausting all possible solutions
Username: Riskyb
Post Number: 193
Nice when you get your amp business sorted out it would be tight if you got it metered. I want to know what they put out.
In my area they are basically the best you can get. Everyone around here has something sheisty like MTX or Kicker.
Pisses me off when I mention RE or something and people are like "ive never heard of that it must suck".
Username: Dustin3
Tigard, OR U.S.
Post Number: 3485
lol. i deal with that like every day. because they only know if mainstream brands, i once went mainstream and will never go back, lol
Username: Blainew
Post Number: 1553
when i tell people that i got the RE 12.1, they are speechless
everyone aorund here knows RE
Houston , TX
Post Number: 842
i said soundstream up there but you have a soundstorm which i knew but still typed soundstream lol, thats my bad
Username: Avirex64
Vallejo, CA USA
Post Number: 22
how much did you pay for the 12.1?
Username: Blainew
Post Number: 1555
Username: Avirex64
Vallejo, CA USA
Post Number: 25
whats the thd?
Username: Cenus
4, 2 0
Post Number: 2300
the thd on a re12.1 is .05%.
Username: Blainew
Post Number: 1556
i got it all worked out
the gain is now set right
the problem is my head unit, and some other things that are just to complicated to explain
but its all figured out
Username: Cenus
4, 2 0
Post Number: 2306
so how does it sound?
Username: Blainew
Post Number: 1557
sounds amazing
doesnt get too loud, bc as i said i need a new head unit, and my current head unit has to have the bass settings at -4 (it goes to +6) bc the speakers rattle
i will get a new head unit with
4 or more volt output
subwoofer output
actual subwoofer control
and speaker crossovers
should be nice
oh and also im running the 12.1 at 700 rms.. so right now i wont be achieving any great SPL numbers haha, but im fine with that
Username: Cenus
4, 2 0
Post Number: 2307
thats what im running it at with the atlas's and they get plenty loud for me. but someday im gonna upgrade to a single 15 with all 1200++wrms.
Username: Riskyb
Post Number: 195
www.sonicelectronix.com has really good deals on pioneer h/units
Username: Blainew
Post Number: 1558
dustin, you got a 12.1??
what head unit, and what kind of wiring??
thanks grant
Username: Cenus
4, 2 0
Post Number: 2308
ya i got the RE12.1, running 2 AA atlas 15's, my HU is a pioneer DEH-580mp, its pretty nice has sub out and sub controls, but only 2.5v outs, but other than that its a nice HU, the wireing is power acoustic 4ga, was allready in the truck, but its pretty big, i got a 4ga ground from stinger and the PA wire is thicker.
Username: Blainew
Post Number: 1559
if my amp doesnt work with a new headunit i will have wasted 350 bucks. im kind of nervous
Username: Cenus
4, 2 0
Post Number: 2311
hopefully everything will work out, was the amp used, if so the price you paid was kinda high, i paid $390 shipped brand new from RE.
Username: Blainew
Post Number: 1560
no it was brand new....
the guys from RE "100 percent guarantee" that i need a new head unit
Username: Blainew
Post Number: 1561
and dustin what did your receipt look like, did it have the date on it??
Username: Cenus
4, 2 0
Post Number: 2312
ya at the very bottom, it has a stamp mark saying "paid" and the right beside it, it says "rr 02/27/06" but why are you asking about the date?
Username: Blainew
Post Number: 1568
i talked to some guy at RE and he just said, ill send you a receipt so u can return it, the reciept has no date...and anyways doesnt that seem weird that he would email me an invoice??
Username: Cenus
4, 2 0
Post Number: 2314
idk, AA sent me an email invoice for the atlas's, but re didn't.
Username: Blainew
Post Number: 1570
screw this im gettin an ED nine.1 tommorow
Username: Cenus
4, 2 0
Post Number: 2318
well what are you gonna do with the 12.1, would you wanna trade plus cash for a kx200.2?
Username: Blainew
Post Number: 1571
im giving it back to the guy, he will probably find out it works fine and sell it on ebay, so if u find a 12.1 on ebay selling from the username shortsord, you know it wasnt abused, all i did was install it, turn it on, then take it out
