Bronze Member Username: Avirex64Vallejo, CA USA Post Number: 20 Registered: Sep-06 | I got 2 mtx 15'' 8500's hooked up to a Hifonics BXi1206D amp, the rms on the subs put together is 1200 watts and the rms on the amp is 1200 watts at 1ohm so it is matched up. Is there any way I can get more from these subs or is this the max I should put to the subs? |
Gold Member Username: CtmikeCt. Post Number: 1815 Registered: Feb-06 | get a better amp. hifonics are overrated so your probably seeing closer to 900wrms from that amp then 1200w. i'd get an amp that does somewhere between 1200-1400wrms. |
Bronze Member Username: Avirex64Vallejo, CA USA Post Number: 23 Registered: Sep-06 | do you have any suggestions in brands? I dont have a budget I just want something GOOD |
Silver Member Username: John_washNashville, Tennessee Post Number: 536 Registered: Dec-05 | Kicker KX1200.1 |
Gold Member Username: CtmikeCt. Post Number: 1816 Registered: Feb-06 | http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1570443/vpcsid/0 /SFV/30046 http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=44 |
Silver Member Username: Adam_sWisconsin USA Post Number: 271 Registered: Aug-04 | Actually from what I have heard is that the new Hifonics....the BXi line is actually very accurate in there power ratings and DO put out what they are rated... |
Silver Member Username: Rob_pregYoungstown, Ohio United states Post Number: 651 Registered: Sep-05 | build a better enclosure. |
Bronze Member Username: Avirex64Vallejo, CA USA Post Number: 27 Registered: Sep-06 | I dont really know how to build enclosures, I bought mine off of ebay for like $50. |
Silver Member Username: Adam_sWisconsin USA Post Number: 274 Registered: Aug-04 | if you have a prefab a new enclosure would deffinatly be a great upgrade to your system. |
Bronze Member Username: Avirex64Vallejo, CA USA Post Number: 31 Registered: Sep-06 | really? I dont really know how to make them but I have some friends who do. What would I change? how would I make it? |
Silver Member Username: Adam_sWisconsin USA Post Number: 275 Registered: Aug-04 | well for one how much space do u have....and is ur box now ported or sealed because if its sealed and you build a ported one it will be a lot louder. |
Bronze Member Username: Avirex64Vallejo, CA USA Post Number: 32 Registered: Sep-06 | its sealed. |
