Box for 18" FI Q
Username: Crayola0
Wisconsin
Post Number: 1069
Says around 6-10 cubes at 28Hz doesnt that seem a little low??
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1306
the tuning? it would optimize sq as it would less peaked curve than a higher tuned box.. but if your getting an 18.. your probably not gettin it for the sq
Username: Fi_car_audio
Hades, NV
Post Number: 7
Correct. The Q is a great daily SQ/SQL sub. You can pop the tuning up some and itll peak harder for a more SQL type application.
