What's a good component set between $200-$300?
Username: Camarobump
Post Number: 12
I have a 1997 Camaro with all of the factory door speakers still in there. The 2 front and 2 back speakers are 6.5"s, and the 2 trunk speakers I believe are 3" tweeters. I want to upgrade to something with crisp, clean sound but can get loud when turned up.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2802
nothing will sound crisp or clean when you turn it up without an external amplifier. do you plan on getting an amp for the speakers??
Post Number: 15
Yeah, could you suggest some amps that would be good for this purpose. I have a urban 300w amp now that I am using for my subs, but I am about to upgrade to a better amp for those. Do you think this amp would be good to use on the the component speakers?
Username: Delsole
Post Number: 797
i think 2 sets of 6.5's and a set of tweets plus an amp will cost more then 300 bills
Username: Jenifer_contreras
Tampa, Florida USA
Post Number: 217
you can start with the infinity component speakers and amp KENWOOD XXV-02A, all together~300$ from e-bay!
Username: Delsole
Post Number: 807
kenwood sucks balls
Username: Adddisorder
West palm, Florida
Post Number: 763
so do infinity componets or atleast the reference
Username: Delsole
Post Number: 815
ya
please dont take it the wrong way cuz of what i said jenifer in my eyes they arent very good,
k baby
Username: Alteraudiousa
Concord
Post Number: 1207
I would worry only about the front door speakers and the middle ones. Your sub in the back is all you need for the rear. I would suggest a good component set up front and the middles get some coax's for rear fill. If you'd like some CDT components, message me and i'll get you them.
Post Number: 16
Are Alpine component speakers worth putting in my Camaro?
Concord
Post Number: 1208
i don't like them but if you must get them only get the Type R or X
Post Number: 17
what would you prefer putting in there?
