Frequency question
Username: Dandandan
Brisbane, Queensland Australia
Post Number: 157
just say you have an amp that has a lpf that is 60hz at its lowest how can you make that tuned lower to 30hz with the same amp
Username: Tozsub
Post Number: 8
you proberly cant
Username: Tozsub
Post Number: 9
wat amp u got anyway
Username: Frkkevin
Lake Worth, Texas US
Post Number: 495
get a bass blocker for whatever frequency you don't want it to go under..
Username: Basshead86
Google is your Friend, FL
Post Number: 4841
why the hell do you want a lpf at 30hz....
your mids can not play anywhere near that low, and loud enough to compensate for the lack of reproduction of that freq. range.
geez
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 526
why the hell would anyone ever want a low pass filter at 30Hz. So you dont want 30-70Hz, but you want 30 and below? You do reallize you'd be losing almost your entire sub bass region? im very curious as to what the goal behind this idea was.
Username: Adddisorder
West palm, Florida
Post Number: 680
you cant even hear past i think 25 or 28hz you can only feel it not to mention most music doesnt hit that low.
Username: Safe_cracker
Chicago, IL US
Post Number: 1415
I take it is a sub amp?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3196
you do realize that a LPF cuts the freqencies ABOVE its set freq....right?
Username: Mendonmafia
Post Number: 182
yea why would you only want to play fq's below 30hz that makes no sence at all. and the mid ranges wont even play at all pretty much or the tweets and hardly the sub.
Username: Dandandan
Post Number: 158
i mean to 30hz not below
Post Number: 4858
then you are talking about a Sub-Sonic Filter.
not a low pass filter.
which acts like a HPF for your sub.
Username: Dandandan
Post Number: 159
thanks muddy
Username: Dandandan
Post Number: 160
so does it mean if you have a crossover to 40hz it will play any note under that to about 30 hz and get low
Post Number: 4874
here's how it works.
you have a sub.
you set the LPF at say....80hz. that means anyfreq. above 80hz...is blocked out. it plays 80-0hz.
and lets sat your box is tuned to 35hz. you then want to set your SS to say....30hz. so...any frequency below 30hhz is blocked out(rolled off) so your sub doesn't play freq. that much below tuning to avoid your sub from bottoming out.
Username: Likeapuma
Washington/Utah
Post Number: 8
Yes, that's exactly right except if your LPF is set at 80 Hz, it won't cut off any frequency above that. It just phases it out. So if your crossover is a 6 db per octave crossover, then the volume of the frequencies above 80 hz will start to be lowered at that rate.
-C
Chicago, IL US
Post Number: 1429
WOW look at this sh!t people finally learning this stuff, lol. Now on you HPF or subsonic you want a steeper rolloff, say 18db/octave to helop eliminate any unwanted"bad frequencies" caused by recording errors or even static. IMO the higher you set you LPF the steeper you want the cutoff because you don't really want a particular sub going to high. This also depends on your size/type/brand of sub. I have a single 15 so I prefer to keep it tight by using frequencies from 25-65 hz, 12's and 10's should be higher. Sure is nice to see people who can talk the sh!t, KEEP IT UP! Polo.. :-O
Post Number: 4879
lol
what the hell was that all about Polo?? lmao
Chicago, IL US
Post Number: 1439
A post where people actually got sh!t right, lol. I remember I posted this answer a while back when people kept getting there fricken HPF/LPF mixed up was pretty hilarious, really. Now I see some people actually retaining the right answers in there memory instead of making sh!t up, lol...:-O
Post Number: 4934
you talkin bout me fOO!!!:-(
lmao.
Chicago, IL US
Post Number: 1440
HELL NAAAA, lol.
Los Angeles, CA USA
Post Number: 5122
polo knows wassup. you know your sh!t man.
Post Number: 5069
that gif is priceless man. LMAO
