Flared ports
Username: Oglejust
Post Number: 94
ok i just make pvc ports... i see in a lot of ur guy's boxes u have ports with flares. do u buy the whole port or just the flare? or do u make them?
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 797
you can buy the whole thing, its alot easier then making it...
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2730
basically, you buy the flared ends and can use their (whatever brand) pipe for the center, cut to length and attach the flared ends.
making them requires a lot of skill. you have to get a torch and heat the PVC (which i think is harmful if not deadly to breath the fumes??) and flare the edges out without splitting the pipe. pain in the a-ss i'd think.
Username: Oglejust
Post Number: 96
where do u buy the flared ends?
Username: Basshead86
Google is your Friend, FL
Post Number: 5009
try the ROE store.
Username: Redliner
Wilmington, Ma
Post Number: 2268
yes brandon it is it has arcenic in it or however you spell it and a ton of other chemicals
Los Angeles, CA USA
Post Number: 5111
if you torch it and burn it then yes you are going to smell the smoke. thats why you use a heat gun.
Los Angeles, CA USA
Post Number: 5112
btw just ask marshall. he seems normal to me. i don't think he inhaled any fumes. lol. unless those fumes make him as smart as he is right now then i don't mind inhaling myself.
Username: Adddisorder
West palm, Florida
Post Number: 706
yeah use a heat gun and someone said push down on it on an upside down metal mixing bowl. so im going to try that some time soon
Stockbridge, GA USA
Post Number: 2733
Parts Express has them
http://www.psp-inc.com/
for more info and theres a link to a store that sells them online too.
Post Number: 5065
i forgot about that shop^^ lol
