Higher tune not louder??? wtf....
Username: Thomas_g
NM
Post Number: 1626
Y does it seem like when i try a higher tuned box say around 38hz, it seems louder when i tune it at 32 or 33hz?? Does ne1 know?? Thanx....
Username: Basshead86
Google is your Friend, FL
Post Number: 5016
cuz you are dumb.
are you increasing the port area when you tune higher???
Username: Thomas_g
NM
Post Number: 1627
Hey Muddy datz fu*ked bro lol u mean like wider??
Post Number: 5018
i am just kidding dude. lol
i mean like more port area....yeah wider, considering you are keeping the port height the same.
Username: Thomas_g
NM
Post Number: 1629
With pvc i have 2 4.25" ports tuned to like 33hz or wut ever, when i screw with the tuning i just leave it with those widths and cut or add to the length.....but i even tried that subwoofer tools calculator with a square vent and it still didnt seem louder.....hmmmm
Username: Thomas_g
NM
Post Number: 1630
O those 2 ports r for 2 12" subs in the same chamber.....
Post Number: 5025
try more port area...isntead of messing with the length. maybe that will help.
Username: Thomas_g
NM
Post Number: 1631
Mission aborted...... :-( DAMN!!!!
Username: Thomas_g
NM
Post Number: 1632
WHOA close........... but isnt that already big enough??...... o by tha way i called dd audio and asked tha prices for the 2512 and 2515 for my location and for tha 12 it would be around $210 w/shipping, and for tha 15 it would be around $240 w/shipping, its only like 30 dollars more so would u just get the 15, or it wouldnt be much different??
Post Number: 5030
hell yeah.
cone area is always a plus.:-)
you are paying thirty dollars more to go from one 12" to essentially 2-1/4 10"s using a very general cone area formula.
Username: Thomas_g
NM
Post Number: 1633
Thanx, thats very ummmm......mathematical lol :-)
Well if i add another 2 4.25" pvc ports do u think it will be to much for 2 12" subs?? Thanx...
Username: Thomas_g
NM
Post Number: 1634
Or would it be just enough for more spl??
Post Number: 5034
try it....hell if i know.
how big is your box.....
Username: Thomas_g
NM
Post Number: 1635
4 cubes excluding ports and subs displacement.
Post Number: 5039
i don't know if aeros are different than Slot ported boxes as far as port area goes, but you have roughly 7 sq.in. of port area per cubic foot. DD recommends 16 sq.in. per cubic foot.
so maybe try to get a little bit closer to 12 or 14 per cube?
Username: Thomas_g
NM
Post Number: 1636
I have 2 cvrs in it, and ive alwayz wondered how tha hell u get the square inches from ur port....
By tha way i just read ur profile and i wuz lmao so bad when i read those funniest threads especially tha 1 with that guy that was all scared cuz his "voice coil" wuz stickin out
lol.....
MuDDy: "so maybe try to get a little bit closer to 12 or 14 per cube?"
So then i should add 2 more lol.... :-)
Post Number: 5046
try it.
like i said...most people only use 2 or 3 aeros.
but with slots people use way more port area for some reason.
and DD rec's 16 per cube with slot ported. so try to get closer to that number and see what happens with aeros.
don't be mad a me if oyu don't like the outcome.
Post Number: 5047
those threads are my top picks lol
Username: Thomas_g
NM
Post Number: 1637
Dont worry i wont be mad, expirementing is tha best way to do things so u can learn from mistakes.....Ne wayz thanx fo tha help dawg l8rz......:-)
Post Number: 5054
