Gold Member Username: Bestmankind
Los Angeles,
CA
Post Number: 5021 Registered: Oct-05
Posted on these batteries are connected in series right? if so why is it like that? i got this picture off of the optima batteries website. |
Gold Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 2686 Registered: Feb-05
Posted on looks like they are in series. i guess hydrolic or air bag systems, whichever that is to the right requires more voltage?? |
Gold Member Username: Carguy
Post Number: 5634 Registered: Nov-04
Posted on The guy could have a 48v charging system. |
Gold Member Username: Southernrebel
Monroe,
Louisiana
Post Number: 3210 Registered: Mar-04
Posted on yep, 48v prolly trying to get more power out of his sony xplodes. (or start a fire w/ em)
Los Angeles,
CA
Post Number: 5042 Registered: Oct-05
Posted on marshall if i get the dd z2 amp and wire 2 8v batteries in series, can i see 16v? also will my alt be able to handle that? |
Gold Member Username: Safe_cracker
Chicago,
IL
US
Post Number: 1431 Registered: Jan-06
Posted on You will need a new regulator for it, I could be wrong but not usually...  |
Los Angeles,
CA
Post Number: 5044 Registered: Oct-05
Posted on what if i get an isolator? that way the battery under the trunk would be normal and the batteries in the trunk will be 16v. |
Gold Member Username: Illuminator
Post Number: 4630 Registered: Apr-05
Posted on But then how would your alt charge 16v batteries when it doesn't even put out 16v itself? |
Los Angeles,
CA
Post Number: 5045 Registered: Oct-05
Posted on true jexx. |
