Like
Archive through July 20, 2006
Username: Tomtit
i've just bought a 1993 ford escort and need to fit a stereo. however the colour coding of the stereo wires in the vehicle is totally different to the codes given on this page and everywhere else i've found online. i've managed to figure out the speaker wires but i can't work out the others. they are:
red, brown, yellow, blue/yellow, brown/white and fat brown.
if anyone can help i'd be grateful
Username: Tomtit
Username: Makmillion
United States
Post Number: 64
2002 Ford Focus stereo wiring..???? reply in the next few hours would be hugely appreciated as I have to do the install at 3:30(it's 10:30)
United States
Post Number: 65
Username: Tjmutlow
Post Number: 2470
DIRECTWIRE WIRING INFORMATION - FORD / FOCUS / 2002 / Audio
Radio 12v orange/black (thick) + radio
Radio Ground blk/yel & blk/grn - radio
Radio Ignition yellow/green + radio
Radio Illumination orange/black (thin) + radio
Factory Amp Turn-on
Power Antenna
LF Speaker +/- wht/blk - gry/blk radio
RF Speaker +/- wht/red - gry/red radio
LR Speaker +/- wht/pur - gry/wht radio
RR Speaker +/- white - gray radio
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 555SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes:
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Username: Crayola0
Thanks Ty i did that and now it works great and sounds great too. Thanks .
Username: Kbenz47
Rochester, New York United States
Post Number: 44
can i get the alarm and cruise info?
Username: Buddha
2006 Ford F150 xlt speaker wire colors???
Username: Tjmutlow
Post Number: 2476
1999 Honda Civic Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness or White 6 Pin Plug behind Fuse Panel
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory White/Black Ignition Switch Harness
Tach Blue Coil
Neutral Safety Wire Black/Blue (-)
Brake Switch Green/White Brake Switch
Trunk Pin Blue/Black (-) Driver's Kick or Alarm Connector right of Column
Parking Lights Red/Black (+) Keyless Entry Module or above Fuse Panel
Head Lamp Red/White left. Red/Blue right at Steering Column
Door Trigger Light Green/Red (-) Alarm Connector right of Steering Connector is Green
Door Lock Green/White (-) Above Fuse Panel or Keyless Module or behind Radio Green Connector
Door Unlock Green/Orange (-)
Driver's Lock White/Red Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Yellow/Red Keyless Entry Module
Horn Wire Gray (-) Steering Column or Green Connector behind Radio
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
• Cruise Information • Stereo Information
1999 Honda Civic Cruise Information
Constant 12V+ White Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/Yellow Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a Brake Switch
Cold Side of Brake Green/White Brake Switch
Tach Blue Coil
VSS Lead Blue/White Passenger's Firewall 3 Pin Connector top Transaxle
Pulses Per Mile 4000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
• Alarm Information • Stereo Information
Username: Hferdjal
May I get the radio wiring diagram for a Chevrolet Malibu 1998? You posted the diagram for a 99 earlier in this thread, but the colors are significantly different for the 98 version.
Really appreciate it man.
Username: Tjmutlow
Post Number: 2479
1998 Chevrolet Malibu Stereo Information
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Rear
Front Speakers 4" x 6" Doors
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Username: Harvestland
how about for a 1998 ford contour?
Username: Mitsibishi23
I NEED WIRING INFORMATION FOR 2000 MITSIBISHI MIRAGE DE SEDAN DESPERATLEY!!!!!!!!!!!!!!!!!!!! HELP!!!!!!!!!!
I NEED STEREO WIRING INFORMATION FOR 2000 MITSIBISHI MIRAGE DE SEDAN DESPERATLEY!!!!!!!!!!!!!!!!!!!! HELP!!!!!!!!!!
Username: Nickwood
i NEED TO KNOW HOW TO HOOK UP MY KENWOOD DECK INTO MY CAR. IT IS A 1995 SATURN AND I CANT FIGURE OUT WHICH WIRES ARE SUPPOSE TO BE HOOKED UP TO WHERE. THERE ARE ALL KINDS OF DIFFERENT COLORS.
Username: Djokfr60
Hi,
Can someone help me on the colors for a Ford Focus TDCI 115 year 05?
Thx a lot...
Djok
Username: Mcarrierd
I need the stereo wiring for a 1993 Mustang. I have searched everywhere for it!
Thanks in advance!
Username: S_king
i need help with the color codes for an '02 Dodge Stratus. thanks in advance
Username: Mitsigirl
hey guys, i need a wiring diagram for a 93 mitsi Colt to get my head unit connected. can anyony help?
Username: Tjmutlow
Post Number: 2481
1998 Ford Contour Stereo Information
Constant 12V+ Orange/Black
Switched 12V+ Blue/Black
Ground Black/Green
Illumination White/Green
Dimmer n/a
Antenna Right Rear
Front Speakers 5" x 7" Doors
Left Front (+) White/Black
Left Front (-) Brown/Yellow
Right Front (+) White/Red
Right Front (-) Brown/Yellow
Rear Speakers 5" x 7" Rear Deck
Left Rear (+) White/Purple
Left Rear (-) Brown/White
Right Rear (+) White/Purple
Right Rear (-) Brown/White
• Alarm Information • Cruise Information
Username: Paster120
Hi i need the stereo wiring for a 1997 na supra. I have searched everywhere for it!
Thanks pad.
Username: Ciera_cutless
Post Number: 41
does anyone have new the color code for the stereo in a 96 acura integra?
Post Number: 42
does anyone have the color code for the stereo in a 96 acura integra?
Username: Clayman2006
I have a 95 Dodge Dakota and I just bought a panasonic CQ-C9701U 70x4 cd player but it didn't come with an owners manual. My question is does anyone know what wire is what on the panasonic wiring harness?
Username: Tjmutlow
Post Number: 2495
they should be makerd is small lettering, but if you have the aftermarket harness for that car(best way to run a radio) the wires will match up.
Username: Tjmutlow
Post Number: 2496
1996 Acura Integra Stereo Information
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger n/a
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Left Rear
Rear Speakers 6 1/2" Side Panels
Username: Tjmutlow
Post Number: 2497
1995-97 Toyota Supra Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (-) Blue
Rear Speakers 5" Side Panels
Left Rear (+) Black
Right Rear (+) Red
Right Rear (-) White
Username: Simko
I have a 2001 sunfire and when I test the wires, no ignition power lights up. could I get the wiring colour scheme plz?
Username: Tjmutlow
Post Number: 2502
could not find 01, maybe 00 will work.
2000 Pontiac Sunfire Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Tjmutlow
Post Number: 2505
alos on sunfire, been awhile since i did one, but it had a relocation harness and i think there was no power ar the harness benind the radio(switched), you can run them direct to fuse block., but double check all fuses first(both sides of the fuse)
Username: Simko
Thanks Ty, that second posting was what really helped me. I couldn't figure out where to get my switched power from until you suggested running direct into the fuse block, which instantaneously sparked my memory. Much appreciated for the help, and thanks for you time!
P.S. 2000 -2001 sunfires do have the same colour scheme for wiring, so does everything else after 1997 up to the 2004 ( with pontiac sunfires)
Username: Trojan_horse
Fayette, MO United States
Can I please get a radio wiring diagram for a 1989 Mustang GT Convertible?
Thanks.
Username: Klyed
I need a 96' ford explorers color codes for new head unit
Username: Tjmutlow
Post Number: 2518
1988-89 Ford Mustang Stereo Information
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Chassis
Illumination Blue/Red
Dimmer n/a
Antenna Trigger Orange/Blue
Antenna Right Front
Left Front (+) Orange/Green
Left Front (-) Light Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Tjmutlow
Post Number: 2519
1995-96 Ford Explorer Stereo Information
Constant 12V+ Green/Purple
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Left Front (+) Orange/Light Green
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Thanks a million Ty! That'll be a big help.
BG
can i get stereo wiring information for a 2000 Mitsibishi Mirage ? ? ? plz?
Username: James_007
hey ty, i was wondering if u got a 1992 toyota paseo colour code and is there a diffrence bewteen a 12v memory wire and a 12v igniton wire?? thanks
Username: M8ball
Aurora, IL USA
Need wiring diagram for 95 ford taurus.
Username: Tjmutlow
Post Number: 2521
1992-93 Toyota Paseo Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Driver's Pillar
Left Front (+) Pink
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Black
Right Rear (+) Red
one wire is constant power and the other is switched
Username: Tjmutlow
Post Number: 2522
1995 Ford Taurus Stereo Information
Constant 12V+ Light Green/Yellow
Ground Black
Dimmer n/a
Antenna Trigger Orange/Light Blue
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Rear (+) Pink/Light Green
Left Rear (-) Dark Blue/Orange
Right Rear (+) Pink/Light Blue
Right Rear (-) Tan/White
Username: James_007
hey i think i need to wire the whole radio back up like power and all that does any1 have lyk colour map for the whole front end of a 1992 toyota paseo. thanks
Username: Stifler92274
anyone have it for a 1992 jetta
Username: Xplorer98
Post Number: 12
I have a power antenna on a 98 ford explorer and it doesnt move when I turn the radio on. I also have a new deck does anybody know what wire I should jump the power antenna to to make it go up when the radio is on?
Username: Tjmutlow
Post Number: 2534
the radio has a power antenna lead on it. make sure you have it hooked up.not the remote turn on wire.
Username: Tjmutlow
Post Number: 2535
1985-92 Volkswagen Jetta Stereo Information
Constant 12V+ Red
Switched 12V+ n/a
Ground Brown
Illumination Gray/Blue
Dimmer n/a
Antenna Trigger White
Antenna Left Front
Front Speakers 3 1/2" Dash
Left Front (+) Blue
Left Front (-) Brown/Blue
Right Front (+) Red
Right Front (-) Brown/White
Left Rear (+) Blue/Green
Left Rear (-) Brown/Red
Right Rear (+) Red/Green
Right Rear (-) Brown/Black
Username: Red_seal
Ty mutlow
would you happen to have the wiring info on a 2002 F-150 Supercab? I searched through all the vechicles you have already posted and I didn't notice it anywhere. Thank you!
Need wiring diagram for 2000 Mitsibishi Mirage
Username: Jpmolt
I have an 05 ford taurus. I'm going to install a cd player with the installation kit. It includes air conditioner switches. However, my car has an air bag light by the ac switches and the installation kit doesn't. Will that cause a problem? If so, what do I do to fix it. Anyone's help is greatly appreciated, thanks.
Username: James_007
Hey i have the radio connect right but i havent got any power it worked once but then when i turned it off i went to turn it back on but now it wont turn back on i have a toyota paseo 1992 and i have cheaked the radio fuse any one got any ideas for me???
Username: Paulperreault06
Biddeford, Maine USA
I need the wiring diagram for a factory radio for my 1997 chevrolet cavalier... Can anyone help me out?
Username: Tjmutlow
Post Number: 2566
Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Nokturnel23
I need help installing my CD player in my 1995 honda civic it has no harness it got cut out when bought...
here are the cars wire colors...
red with yello line
brown white.
gray white
blue yellow
black I know this one is ground...
yellow with red
white with blue.
red with black.
gray with black
blue
brown with black
red with green...
Now my CD wire harness colors are...
Red some what pinkish...
orange
blue with white
green
green with black
gray
gray with black
yellow
white
white with black
purple
purple with black
if some one can tell me which car wire gose to what CD harness color to make it work that would be great I have been waiting way to long and driving with out music sucks the big one..
email me with any help..
thanks ahead of time.
nokturnel23@verizon.net
also I don't know if I shorted any wires cause they were not coverd at all.
All of the fuse's are fine and the CD player fuse I dont know what would happen if it shorted so TY the man let me know and the above is the most inportant thing right now.. thanks buddy.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 118
Hi, I need wiring info on a 1997 Ford Probe. I took out the factory amp thats inside it and I also need to know what wires are what that come out of it.
Username: Mitchman
Appleton, Wi Usa
I need stereo color codes for a 1993 ford taurus gl
Username: Tjmutlow
Post Number: 2572
Matt H, here is the wiring diagram for that car, alos use a test light an make sure you have power on both acces and constant power. the wires on the radio s/b marked. just match up/
1995 Honda Civic Stereo Information
Ground Black
Dimmer n/a
Rear Speakers 5 1/4" Rear Deck
Username: Tjmutlow
Post Number: 2573
1992-93 Ford Taurus Stereo Information
Dimmer n/a
Antenna Right Front
Thanks ty I will try it I hope it works and I have no clue what a test light is....
wait ty you said that blue white is the 12V+ but my car only has
Blue
Blue Yellow
Or white with blue......
So which one is it?
Username: Tjmutlow
Post Number: 2580
use a test light to find out.
Ty what is a test light and where could I get one?
Cause I hooked up every thing and only had 2 wires left and non of them turned the power on...
Username: Tjmutlow
Post Number: 2581
just a tool that has a wire on 1 end(ground) and a light tester on other.it allows you to test for current, or if you have a multimeter it will work also. you can get cheap one at advance or autozone....
are you sure its called a test light cause I went to auto zone and they had no clue what I was talking about.....
Username: Qwerner
Inwood, IA United States
any one help with wiring diagram for 2000 dodge durango
Username: Tjmutlow
Post Number: 2584
then they are stupid, it can be called a circuit tester, bust most people call it a test light....
Username: Tjmutlow
Post Number: 2585
2000 Dodge Durango Stereo Information
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground n/a
Illumination Black/Yellow
Dimmer Orange
Antenna Right Front
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Brown/Yellow
Right Front (-) Brown/Light Blue
Rear Speakers 6 1/2" Rear Door
Left Rear (+) White
Left Rear (-) Dark Blue/Red
Right Rear (+) Brown/White
Right Rear (-) Brown/Orange
Username: Junkyardogs
Hey Ty I have a 94 Acura Integra, can you help me out with the wiring colors. Thx
Username: Dixienormas
Hey Ty, i used the 82' - 85' wiring info, you supplied earlier to someone, to install a new head unit in my 89' celica. so far all worked out well except i was left over with a pink/blue wire that was coming from the car, what is that for? would i be able to get the 89' celica wiring info?
Cheers mate, luke.
Username: Rugman29
Moncton, N.B. Canada
Hi all. I am lookig for a wiring diagram for a 2000 Intrepid without the Infinity system. Thanks
Username: Theshanefactor
I need the wiring colors for a 1988 Toyota Corolla FX... help! Thanks!
Username: Liquidgrin
I need the wiring colors for a 1990 ford e150 van, PLEASE! Thank you.
Username: Kdawg
ok i have one lightning audio 900 watt 4 channel amp,one lightning audio 600 watt 2 channel amp,one pair of 6.5" 420 watt coaxial speakers,one 12x12"kicker L7 1000watt,one boss audio crossover,and one 1.0farad capacitor. my problem is my 900watt 4 channel amp keeps kicking off when i turn it up loud. please help
Username: Skeeter_alamo
does anyone have a 2002 Ford econoline E250 radio wiring diagram?
disregard ford e250. i traced it out.
Username: Ccicecold83
Mt.laurel, New jersey USA
i need the wiring schematics for a 1990 740 volvo Turbo n will the wires hook right up to the head unit because the stock unit came with a plug for the back so the wires were wrapped as one i have a year old pioneer head unit would it be easier for me to hook it up cause thats how i wanna do it because i didnt think it be that hard or would it be easier to get professionally done because of the way everything is set up like the plug in for the speakers thanks alot for the help
Username: Tjmutlow
Post Number: 2593
1985-93 Volvo 740 Series Stereo Information
Constant 12V+ Green/Red
Switched 12V+ Orange
Ground Black
Illumination Gray
Dimmer n/a
Antenna Trigger Red
Antenna Left Rear
Left Front (+) White/Yellow
Left Front (-) White
Right Front (+) Gray/Yellow
Right Front (-) Gray
Left Rear (+) Yellow/Brown
Left Rear (-) Brown
Right Rear (+) Yellow/Black
Right Rear (-) Black
thanks alot man ill let u no if i have any problems
Username: Damien10101
Can any1 help me out with stero wire info for 1995 Ford Probe GT. That be great thx
Username: Ruppe89
GA, GA USA
I need a wiring Diagram for a 1993 Honda Ciciv please. E-mail me or send it on here Ruppe89@yahoo.com please.
Username: Ruppe89
GA, GA USA
I need a wiring Diagram for a 1993 Honda Civic please. E-mail me or send it on here Ruppe89@yahoo.com please.
Username: Intrepid123
I need a wiring diagram for a 2001 pontiac grand am gt. if you can help me i would really aprecciate it.
Username: Jjspano
Need wiring for a 1997 pontiac Grand prix stereo
Username: Smok3n
Hi all, Im trying to install A CD Changer for my 1999 honda accord. I have stock CD player. I need the color diagram for the Constant 12v and Ignition 12v. Thx Guys
Username: Corollaman1234
Yo whats up guys, i am going crazy trying to find the stereo wiring diagram for a 1999 toyota corolla. If anyone could help it would be most appreciated. Thanks.
Username: Jtmoney313
i have 2003 olds alero with the stock stereo. can i hookup a 2000watt
nitro amp to my stock stereo? if yes please help me out by e-mail at
jtmoney313@charter.net thanks!!
nitro amp to my stock stereo? if yes please help me out by e-mail me at
Username: Brendon
Windsor, ON
I have a 1997 Ford Mustang with the 460 Mach audio system. I am putting in a Sony Explode cd played. I have purchased the FDK10 wiring harnes for the install and have managed to get the stero to power up and the radio to work but for some reason the cd player comes on and playes cd's but there is no sound from the cd. Any ideas what is wrong? Any help would be appreciated.
Brendon
Username: Robbi
wiring diagram for 93 explorer w/ jbl system.. Thanks
How do you remove the paneling around a stock radio of a 2003 Olds Alero??? Any info would be helpful and please email at my email address jtmoney313@charter.net
Username: Fastuff
Would a stock 6 CD radio from a 2002 Ranger work in my 1999 F-150 without wiring or mounting changes?
Username: Wholley
hey all..looking for color coded wiring diagram for a 1995 Jeep Grand Cherokee, to install an Alpine I've had for years thats "been around the block"...and by that i mean the harnesses have been removed at one point or another! thanks alot.
Username: Daneliamarco
San Antonio, TX USA
Anyone help with wiring diagram for 02 Isuzu Tropper w/rear glass am/fm antena?. Thanks a lot
Username: Bri_bri_marie
my boyfriend is trying to install a pioneer stero in my truck. Its 89 ford ranger but he has no idea what the wires are. Can someone tell me what they all mean so he doesnt break nething. email me at bri_bri_marie@yahoo.com thanks.
Username: Tjmutlow
Post Number: 2633
brandon A, does the radio play and not just the cd p[art, idf so the wires are criossed on the harness(amp turn on and power antenna)
Username: Tjmutlow
Post Number: 2634
1993 Honda Civic Stereo Information
Constant 12V+ White/Blue
Ground Black
Dimmer n/a
Username: Tjmutlow
Post Number: 2635
1999 Honda Accord Stereo Information
Constant 12V+ White/Purple
Switched 12V+ White/Black
Illumination n/a
Dimmer n/a
Antenna Glass
Left Front (+) n/a
Left Front (-) n/a
Right Front (+) n/a
Right Front (-) n/a
Left Rear (+) n/a
Left Rear (-) n/a
Right Rear (+) n/a
Right Rear (-) n/a
Username: Tjmutlow
Post Number: 2636
PONTIAC / GRAND AM / 2001 / Audio
[PRINT THIS PAGE]
Radio 12v orange + at radio
Radio Ground
Radio Ignition yellow + at radio
Radio Illumination
Factory Amp Turn-on
Power Antenna dk. green at radio
LF Speaker +/- tan - gray at radio or LF speaker
RF Speaker +/- lt. grn - dk. grn at radio or RF speaker
LR Speaker +/- brown - yellow at radio or LR speaker
RR Speaker +/- dk. blu - lt. blu at radio or RR speaker
Back to Top
Username: Tjmutlow
Post Number: 2637
1997 Pontiac Grand Prix Stereo Information
Ground Black
Illumination Brown
Dimmer Gray
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Ground Black
Illumination Brown
Dimmer Gray
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Tjmutlow
Post Number: 2638
1999 Toyota Corolla Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Left Front (+) Pink
Left Rear (+) Black
Right Rear (+) Red
Facebook
Shop Related Deals
Directory
