Polyfil???
Username: Alpineduder
So u can jack up my sy..., Hell no C-a-n-a-d-a
Post Number: 56
So i have a 10" type-s in a sealed box that is .41 cubic feet. Recommended box volume for the sub is 1 cubic foot, if i use polyfil will it make it ssound like subs in a bigger box??, and instead of polyfil can i just use and soft fluffy material?
Username: James1115
Ct
Post Number: 6210
you can use polyfill, or fiberglass. Thats a big big gap polyfill wont fill that gap. build a bigger box.
Username: Oglejust
Post Number: 54
dude just build a simple box...12x12x12 is 1^ft
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2612
poly fill will only add about 10%. it won't work in your case, a new box will need to be built.
12x12x12 internally will be 1 cube. you have to take into consideration the thickness of the material and sub displacement when calculating volume.
