Sugestions please
Username: Silvermopar
Nebraska
Post Number: 31
ok i just got a pair of 800watt 12inch kicker cvrs. i have about a 150watt output from an amp/eq(i would like to use this too cuz of the 10band eq and cool lights). can i just and another amp? and if so what modle/brand? budget is 50 bucks
thanks for sugestions
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8638
"budget is 50 bucks"
ur not serious are u???????
Nebraska
Post Number: 33
ya cant u chain amps and get more than double the rms that you first had? iv seen amps on ebay for under 50bucks i jus dont kno what to get. and for a fist system i think it would be ok
Username: Riskyb
Post Number: 98
Powering both those subs to there potentials is not possible with 50$ unless you get a really really good deal on a used one.
Username: Cenus
420 , 420 420
Post Number: 2185
LOL 50 bucks http://cgi.ebay.com/MTX-Thunder-801D-Amplifier-Like-New_W0QQitemZ260022463365QQi hZ016QQcategoryZ39735QQssPageNameZWDVWQQrdZ1QQcmdZViewItem theres a mtx 801d you might be able to get for under $50, but seriously save more money.
Username: Illuminator
Post Number: 4276
Hey Dustin in that auction:
quote:
I used only 3 weeks and just switched to Sony Xplod 1200 watt amp.
LOL
Los Angeles, CA USA
Post Number: 4833
$50 will get you the amp kit for your second amp. come on man spend a little.
Username: Cenus
420 , 420 420
Post Number: 2187
ya i seen that, LOL i just chuckled, his loss.
