Bronze Member Username: Bdizz54Post Number: 21 Registered: Jul-06 | You can get 100 sq FT. for $110 on ebay is it worth it or not? |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3007 Registered: Oct-05 | fatmat is alright. a lil thin, and doesnt have a super adhesive, but it will work. |
Bronze Member Username: Bdizz54Post Number: 26 Registered: Jul-06 | Do you think it is worht $110 for 100 sq. FT.? |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8594 Registered: Jul-05 | nope i think edead v1se is .88 per foot |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4477 Registered: Aug-05 | v1se sucks, its asphault-based. get the RAAMMAT BXT. or Damplifier by Second Skin. best for your money.^^^ |
Gold Member Username: FandimReno, Nevada United State... Post Number: 1316 Registered: Jun-05 | v1se isnt aslphalt based anymore. ![]() |
Gold Member Username: FandimReno, Nevada United State... Post Number: 1317 Registered: Jun-05 | Butyl Mass Layer. eDead v1SE² uses a new butyl core for the highest heat resistance possible. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4500 Registered: Aug-05 | b.s. check this out baby ![]() http://www.sounddeadenershowdown.com/ |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4501 Registered: Aug-05 | i don't mean b.s. about the new stuff...but the old stuff was GARBAGE....and and stinky too. lol |
Gold Member Username: FandimReno, Nevada United State... Post Number: 1318 Registered: Jun-05 | I like the new stuff.. odor free. ![]() |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3063 Registered: Oct-05 | yea, the edead v1se is some good stuff. i have it all over my car, and has held up through summer ![]() and that site muddy, tests the sound deadeners at like 170-200 degree's. its never gonna get that hot in your car. yes, the second skin and dynamat held up nicely, they are still fckin expensive. IMO |
Gold Member Username: FandimReno, Nevada United State... Post Number: 1319 Registered: Jun-05 | BTW - in that review - he's reviewing the older stuff when eDead v1 and V1SE really were asphalt based.. but they've since changed to the butyl.. would be interested to see those tests done now, how the edead holds up, etc. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4813 Registered: Oct-05 | fatmats are cool. i bought 50sq for $40 on ebay. they work great. i've also use the edead v1se. the one that smells like asphalt comes off in hot weather but the newer version works great. |
