Box questions
Username: Mendonmafia
Mendon, Ny Usa
Post Number: 52
How critical is box braceing? is it still nessicary if i use 1" thick MDF. and which way do i face my subs towards the back or front. i can fold my rear seats down some times if i dont have ppl in the back. and also is the Digital design porting rule a good rule for all subs or just theirs. and and last should i stuff my box with poly or no. infinity says to stuff a 1.75 cuft ported box with 1 inch of poly on all sides. im going to be building a 2.5 to 3 cubic foot ported box for 2 infinity kappa perfect 12.1 single voice coils. if i stuff it alot like 2 or 3 inches on all sides will that make a 2.5 cuft box seem like a 3.5 cu ft box. i dont have any experience with box stuffing. and if i should stuff how do i keep all the stuffing from coming apart.
Los Angeles, CA USA
Post Number: 4753
if you use 1" mdf then i don't think bracing is necessary. especially for those subs in the size box you describes.
polyfill in ported boxes? i've never heard of anyone trying that out.
Mendon, Ny Usa
Post Number: 54
yea i thought if was very strange myself but infinity calls for a 1.75 cu ft ported box with 1 inch thick poly on all sides i guess ill just screw it and make the 3.5 cubic foot box.
