Not sure which way to connect subs. Serial or Parallel
Username: Alnshan
Post Number: 8
I just bought 2 JL Audio 12w3v3 subs and they came in a box and pre-wired. The store I bought them from said it was wired in serial, but I have the option to wire them in parallel. What's the difference??? If I do keep them in serial...is there a different way of wiring it to my amp or can I just simply connect the red to the red and the black to the black???
Username: Alnshan
Post Number: 9
Anyone???
Username: Frkkevin
Lake Worth, Texas US
Post Number: 398
the different wiring config with change the ohm load the amp will see.. what is the coil config on the subs? what kind of amp do you have?
Username: Cenus
420 , 420 420
Post Number: 2175
what amp are you getting and are the subs dvc4 or dvc2 phm.
Los Angeles, CA USA
Post Number: 4737
the jl 12w3's are svc. you still need to take it out of the box to check what ohm it is. if i were to take a guess they are 2ohm. thats why it is wired in series. so you would get a 4 ohm load. that is just my educated guess so you gotta ask the people where you got it or take it out of the box to see. i am sure it says it on the sub.
Username: Alnshan
Post Number: 10
Correction...I bought the 12W3V2 D4 and not the V3's. Sorry
I'm running them with a JL Audio 500.1.
Username: Dustin3
Tigard, OR U.S.
Post Number: 3053
then it doesnt matter, cause the JL had a Reg power supply. just wire to 1-4 ohms. www.the12volt.com
Username: Tjmutlow
Post Number: 2717
the 500/1 is stable 1.5ohms to 4 ohms, and leave it series at a 4ohm load, there would be no difference in changing the wiring, except that the amp will prob get real hot or clip because it is below ohm load capability.
Username: Alnshan
Post Number: 11
so leaving it in series would prevent the amp from clipping???
