New components.
Username: Crayola0
Wisconsin
Post Number: 362
I have a 199 dodge durango and all the speakers are blown and i dont know what kind they are. they are infinity but i dont know if they are coxial or midranges and that. and i dont know how to install them cause they have a plastic piece attached to the door that only has 3 screws and a plastics grill built into the plastic door cover to hide the speaker.
Username: Crayola0
Wisconsin
Post Number: 400
anyone?
Username: Crayola0
Wisconsin
Post Number: 479
anyone? All i know is that the speaker has to have 3 Tabs that snap into a frame thing.
Username: Riskyb
Post Number: 68
1. Go to your local stereo shop.
2. Ask them to look at your vehicle
3. Listen to what they reccomend
You don't quite know enough for us to help you lol.
Username: Crayola0
Wisconsin
Post Number: 494
lol...if the charge me for them to look at it im gunna be so mad..lol
Username: Dkchillin
Vermont
Post Number: 234
search online for a Dodge Durango forum and check their car audio section for information on your system. There's a vehicle specific forum for nearly every car out there, you're bound to find the info you're looking for or at least someone who can walk you through the process.
Username: Sonyxplode
get sony components
Username: Justababyboy
Philly, PA
Post Number: 118
Why don't you just take the door panel off yourself...it is fairly easy..there are guides on crutchfield on how to do this
