Gold Member Username: Thomas_gNM Post Number: 1760 Registered: Oct-05 | Im new to the world of car alarms, is it easy to install 1?? Thanx.... |
New member Username: MotomazeLondon, Ont Canada Post Number: 2 Registered: Sep-06 | if you havent done it yes. you half to hide absolutely every wire |
Gold Member Username: Thomas_gNM Post Number: 1801 Registered: Oct-05 | Is it about as hard as installin an amplifier or Head Unit?? |
New member Username: MikeldeanConowingo, Md USA Post Number: 1 Registered: Sep-06 | Operating Instructions? I bought the item listed below but either I have misplaced the instuctions or didn't get them. It has Wellseek System Board. Does anyone know where I can get instructions? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=60202%26item%3D140022173085 #1 KEYLESS ENTRY/TRUNK RELEASE REMOTE CAR ALARM BRAND NEW UNIT IN THE BOX Description CONTENTS IN THE BOX 2 REMOTES, SIREN, BRAIN UNIT, OVERRIDE SWITCH, SHOCK SENSOR, WIRING, RELAY, INSTRUCTIONS, LED, & ANTENNA FEATURES REMOTE KEYLESS ENTRY, CENTRAL CAR LOCK, REMOTE TRUNK RELEASE, REMOTE CAR LOCATOR, SMART LED INDICATOR, REMOTE PANIC, ACTIVE CAR JACK PROTECTION, REMOTE CONTROL ARM/DISARM, MUTE SECURITY MODE, STANDARD SECURITY, MODE AUTOMATIC REARMING, EMERGENCY ALARMING, ARMING REMINDER, TRIGGERED STATUS WARNING, DOOR STATUS WARNING, VALET MODE, DIRECTION LIGHTS FLASH AGAINST DOOR OPENING, AUDIBLE ARMING CONFIRMATION ON/OFF SMART ARMING DELAY, EMERGENCY OVERRIDE, 500 FOOT EXTRA LONG RANGE, & FCC APPROVED. ![]() |
Gold Member Username: Thomas_gNM Post Number: 1810 Registered: Oct-05 | hey nugga start ya own thread!! |
