Silver Member Username: Tiggerboi87Pensacola, FL United States Post Number: 166 Registered: Jun-06 | Are these boxes worth the money? |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 878 Registered: Mar-06 | almost if you know how to build one its alot cheaper, you just have to figure the equations, but thats pretty tough, if your new just by one youll def be happy with it |
Silver Member Username: Tiggerboi87Pensacola, FL United States Post Number: 167 Registered: Jun-06 | how do you think one would make a TSX 15 sound with about 1200 watts of power in a blazer? |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 879 Registered: Mar-06 | jizz |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 604 Registered: Mar-06 | ^^^well not my first reaction but... yeah like troy said, if you don't know how to build a good box or are just plain lazy, it pays off. also, if you are going to get a good sub it's nice to know that you are getting the subs full potential |
Silver Member Username: Tiggerboi87Pensacola, FL United States Post Number: 168 Registered: Jun-06 | ok so i could make a box myself or have someone at a shop make one for me that can get the subs full potential for a much cheaper price? |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 608 Registered: Mar-06 | depends on the shop. if you really trust the shop then yeah, but a lot of them do not build very good boxes and they aren't built to maximize your specific woofer. the shop i work at doesn't build very good boxes. i've seen them work on a box and i wasn't impressed and a lot of other shops seem to be the same. |
Bronze Member Username: Xstokes88San Antonio, Texas United states Post Number: 54 Registered: Nov-05 | where do u go ta find how ta make a tcab box..or sumthin like it.. |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 611 Registered: Mar-06 | tcab is a company not a style www.thecaraudiobox.com |
Bronze Member Username: Xstokes88San Antonio, Texas United states Post Number: 55 Registered: Nov-05 | o ok..wut makes their boxes so much better than everybody elses..i heard of em but i never heard one n person..just online.. |
Silver Member Username: Troy81Tavernier, Fl Us Post Number: 880 Registered: Mar-06 | they have a formula they use to make there boxes, and i happen to know it but im not gonna tell you |
Silver Member Username: Crayola0Wisconsin Post Number: 386 Registered: Jun-06 | y would u even say u know it then...now that u brought it up u have to tell us all..lol |
Gold Member Username: Cenus420 , 420 420 Post Number: 2118 Registered: Jan-05 | if you want a box and don't want to make it yourself talk to ATF he makes very good boxes and his prices are pretty decent. |
Gold Member Username: Alex_fNear lexington, Ky Us Post Number: 1219 Registered: Nov-05 | email farrisaudio@gmail.com and i can give you a quote. Thanks for spreading the word dustin. |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4209 Registered: Aug-05 | from another thread i posted in,
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4210 Registered: Aug-05 | i meant to say straight port not bent* |
Bronze Member Username: RiskybPost Number: 32 Registered: Feb-06 | I have used PVC pipe before with good results. I was wonder how do they put the flare on the ports they use? |
Silver Member Username: Demon_prideCrowder, Oklahoma USA Post Number: 200 Registered: Oct-05 | Grant you have to buy the ports like that. PE has them and so do a few other online stores. They are kinda expensive though. |
