Coil Stink!!!
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 357
Ok I bought a 15" Memphis Mojo Dual 2ohm and i had it hooked up to a Fusion 1404! subs in a 6.3 cuft box ported to 35hz. Well I took out the sub then put insulation in the box still using the same amp hooked up in 4ohm just like before! well i bought a memphis 1000D and hooked it up in 1ohm and now i have a lot of coil stink? it is cause the insulation in there or is it about to blow! the sub starts to blow out warm air after some abuse. There wasnt any coil stink with the fusion amp and now there is with this amp! it smells like weeds in ur yard and stuff! What should I do? Take out the insulation? Take the sub back? It isnt even a month old!
