4 12" kicker solobarics L5 and a planet audio 2250 monoblock amp
Username: Kandy_cadillac
i just installed this system in my cadillac yesterday and for some reason it is not hitting as hard as it should.. i have not had a chance to look at how the subwoofers are wired so that may be the reason. also can it be because i have some cheap boxes? any suggestions.. thanx
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1396
how much did u spend on the L5 and tht amp.....wuts the specs on the amp????
Post Number: 1398
bumpo
i got all four L5's . the amp, and a 1.5 capacitor for 500 bucks..
Planet Audio TT2250 Class D amp
RMS Power into 4 Ohms 800 x 1
MAX Power into 2 Ohms 1500 x 1
MAX Power into 1 Ohm 2250 x 1
THD at 1 Watt, 4 ohm 0.30%
THD at Rated 0.50%
Signal to noise Ratio, below rated power output 100dB
Frequency Response, at 1 watt, 4 Ohm 15Hz to 150Hz (+/-3dB)
Frequency Response, at Rated Power, 4Ohm 20Hz to 250Hz
(+/-3dB)
Damping Factor at 20 Hz, 4 Ohm 400
Crossover: Low Pass 50Hz-150Hz, 24dB/Octave
Crossover: Subsonic (high Pass) 15Hz - 40Hz, 24dB/Octave
Bass Boost 0 + 18dB
Phase Control 0 to 180degrees
Input Sensitivity 100mV to 2V
Input Impendance 10K - Ohm
Line Output Impendance 100Ohm
Peak Current consumption, at rated power into 1 Ohm 175 Amperes
Dimensions (W x H x L) 11.34 x 2 1/4 x 19 9/16
Username: Dadydolas
Post Number: 67
having your subs in the right box will make all the differrence
Post Number: 1400
OMG ur joking u spent 500 on 4 l5s???
damn im sry u got ripped out the @$$....MAX power has nuttin to do with power output consider tht an imaginary number tht u can NEVER reach...wut max is a tool used by dealers to make u buy it..so ur screwed thier is no way tht ur gettin tht power....if i were u i would return were ever u bought tht or see if the guy can give u the money back or sumthing....tru box makes a diff but thier is no need for 4 subs two 12" or 15" subs will be fine.......
^^^^^^^^^^if u dont give a crap bout wut i sed just ignore me..but u will hate those subs wen here u hear a pair of great subs tht u couldve bought for the same price
man you dont know what your talking about.. have you checked the price on all this.. your the only guy that says that its not a good deal..
Username: Denali_on_22s
Maryville, TN Us
Post Number: 122
L5s just basically suck dude im sorry... consider buying a couple L7s or soem CVX or sumthin L5s just blows... not to meant planet audio pretty much sucks as well... u probably over paid for the amp and def overpaid for the subs....you can find L5s on ebay for 100 bucks buy a bigger amp if you expect those subs to hit harder
Post Number: 1401
charlie
let me guess u talk to ur frins who no nuttin bout car audio...yea or a dealer told u u had a good deal...well im tellin u u fucked up i tryed to be nice then u say i no nuttin...HAHAHA if only u new.....u came for help and i gave it...thts y i HATE comin on this forum u guys think ur always right....u guys dont no ur @$$hole from ur dickhole u are an idiot my frin
Username: Ctmike
Ct.
Post Number: 1149
charlie, listen to everyone else, you got ripped off! l5's are the worst subs kicker makes, and that amp is a piece of sh!t to. either return them or try selling them, that's your best bet.
