****6.5" speaker recommendations****
Username: Audiobliss21
Post Number: 8
I was wondering if anyone could give me some advice on door speakers. I
want 6.5's, and my budget is $800 for the pair. I want NO DISTORTION,
AWESOME midbass output, and good sound quality as well. Any help would be awesome.
Username: Dkchillin
Vermont
Post Number: 200
does the $800 include the amp you'll need to push them properly, or is that $800 for just the speakers?
Post Number: 9
$800 is just the speakers. I guess $600 for the amp or so. I wanted to decide on the speakers first, then whatever amp I need to push them I'll get. If you want to give me a recommendation for both thats cool.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 230
Heres some:
Kicker:
http://www.sonicelectronix.com/item_3603.html
Amp for Kickers:
http://www.sonicelectronix.com/item_2096.html
http://www.sonicelectronix.com/item_4811.html
http://www.sonicelectronix.com/item_6724.html
MB Quart:
http://www.sonicelectronix.com/item_6172.html
Amp for MB Quart:
http://www.sonicelectronix.com/item_6894.html
http://www.sonicelectronix.com/item_5400.html
http://www.sonicelectronix.com/item_2522.html
There you go. Two diff speakers, 3 diff amps for each one. Hope it helps!
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2471
Rainbow :-)
for $800 you can get anything up to the Profi vanadiums (i have thoes, 3-way set)
http://car.rainbow-audio.de/home/home.php?lan=2
other brands i'll suggest would be MB Quart Q's, DLS, Focal, Morel, Dynaudio, SEAS, Polk SR's...even the Cryatal components have got great reviews.
Post Number: 10
Thanks guys for your help! I think I have plenty of choices on my plate. now.
