Speakers cutting out when car is started.
Username: Trikk18722
Saugus, MA US
I just installed a sony cd player in my 1996 Dodge Intrepid ES and when the car is started the speakers start to go cut out. But when the car is not started and i put the cd player on everything works fine and the speakers dont cut out at all. Anyone know what the problem could be? thanks
Username: Illuminator
Post Number: 3494
Do you have a factory amp?
Username: Tjmutlow
Post Number: 2645
does it do it in both radio and cd mode...
Saugus, MA US
I believe there is a factory amp but not 100% sure ... yes it does it both in radio and cd mode
