C12 amp to power them
Username: Eseesai
Post Number: 133
since my neighbor wants an amp for less than 100bucks i was talking to Chauncy and he is selling ma a bazooka p.miller series amp for 55buck but i was also looking at this amp here's the link:
http://cgi.ebay.com/DUB-MAG-AUDIO-DUB2502-AUDIOBAHN-2CH-500-W-AMP-AMPLIFIER_W0QQ itemZ9734504350QQcategoryZ48597QQrdZ1QQcmdZViewItem
would this power them alright to their full potential since the are 150wrms a piece and its two of them?
Username: Insearchofbass
Post Number: 4815
if your subwoofers are 4 ohm versions a piece then you need an amp that is 2 ohms stable bridged putting out 300 rms which is true power or find an amp that puts out 300 rms at 8 ohms bridged...that would be your choices if the subs are 4 ohms each
ps...a little more rms power than they can handle wont hurt either...my cousin owned a c12 kicker
Username: Eseesai
Post Number: 134
so what else would u recommend that is under my neighbors budget SEAN?
he could maybe spend an extra 10 to 20 bucks if it helps which i know it wont alot but its his budget?
Username: Eseesai
Post Number: 139
i got another question my neighbor just told me his C12 only have one positive and one negetive both are like that so does that mean that they are 2ohms?
Username: Eseesai
Post Number: 140
so does anyone know if the r two ohms then?
Username: Eseesai
Post Number: 141
no one?
Username: Eseesai
Post Number: 142
i need to know anyone out there
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7643
it should be on the sub, if not ask him to see the manual
Username: Eseesai
Post Number: 143
he doesnt have the manual, but he told that each of the subs has one positive and one negetive?
Post Number: 7644
yeah, but that has nothing to do with ohms....
Username: Eseesai
Post Number: 144
oh and by the way Chauncy my neighbor said he wants a stronger amp because he might change to something else later thats all he said my bad i thought he would of wanted it...
hey do u guys think this amp would be good for the kickers its an MA Audio M689i 800 watt 2 channel amp this is the link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D9737394674%26&sspagename= STRK%3AMEWA%3AIT%26
let me know
