Ported box only sub?
Username: Jinster
Post Number: 99
on the manual of my dls MW 110, it recommands a ported box and says sealed is not recommanded. can a subwoofer be designed so that it actually benefits from the characteristics of a sealed enclosure when put in a ported box? meaning it will sound even tighter and faster with a ported box. or do they just say this cuz they believe most customers won't be saticefied with the loudness of this woofer when put in a sealed enclosure?
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 321
if it says sealed not recomended that means that its mainly a SPL woofer. if its ok with either enclosure it can go both ways. the enclosuer has alot to do with the type of sound it produces
Username: Jinster
Post Number: 101
so it's gonna sound like crap if i put it in sealed?
Username: Jinster
Post Number: 106
will it? sorry, i really need some answers. and fast.
Username: Thomas_g
NM
Post Number: 915
If its a good sub it wont sound like total crap, but it wont sound as good as goin ported, just go ported man.
Username: Lexuscoop
Post Number: 342
go ported, if thats what it recomends it would sound BEST in a ported built to specs
