Will this kill my sub?????
Username: Splmonster
Post Number: 138
well i tried my hand at box making, it came out decent but on the outide it doesnt come together PERFECTLY but is decent and i caulked in the inside corners is that ok or not? will it hurt my sub?
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 813
well it cant physically hurt the subs....it might sound funny....depens on how off the corners/sides are....if its like a 1inch gap...and u used caulk to seal it up yeah performance is gonna be bad....but if its samll u prolly wont even know
Username: Matt12490
Benicia, California USA
Post Number: 969
no thats not good. how big is the gap?
Username: Fandim
Reno, Nevada United State...
Post Number: 1031
I would recomend maybe taking a 2" wide piece of 3/4" or larger, and screwing it/sealing it VERY well along the length of the gap going down your box, ontop of the caulking you used, just to make sure it's 100% sealed.
Username: Kingjames
OH USA
Post Number: 164
well its like really small and its all selaed inside but there i like a 1/16 or 1/32 of inch gap on the edges
Username: Dandandan
Brisbane, Queensland Australia
i have a subwoofer 32 of em in my room ha and 4 1000watt amps and equilizer hahahaha
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 488
wtf danny? what was that all about.... are you mental... have you gone insane.....
but yea i would fix that by recutting new wood..... the gap weakens the box... it could end up blowing out...... pressure....ya know...
Username: Johammbass
Cork, Cork Ireland
Post Number: 225
or maybe you should just buy a new box:-)
Username: B101
Queen City, NC USA
Post Number: 2929
leakin boxes will blow a sub!!
Post Number: 139
ill take pics and show u how small the they are and see if u guys think i should redo it
