$400 1600 watts?
Username: Skies
Courtenay, British Colu... Canada
Post Number: 100
Anyone know of an amp that'll do at least 1600 watts for around $400-$450?
Thanks in advance
Username: Ctmike
Ct.
Post Number: 664
http://cgi.ebay.com/HIFONICS-BXi1606D-1600W-MONOBLOCK-Class-D-Amp-NEW-06_W0QQite mZ9731553894QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Grebnereon
Post Number: 80
ummm,,if you are goining for a budget setup,thats pretty expensive, but if you have a little money to throw around and you want to get something of real good quality, then it isnt too bad, what brand is it? and what setup are you wanting, budget? or not
Username: Ctmike
Ct.
Post Number: 665
http://cgi.ebay.com/Orion-2500d-amp-Wcc-D5000-amp-5000-watt-FREE-SHIPPING_W0QQit emZ9730615516QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Skies
Post Number: 103
sorry, when i posted the board wouldnt let me post again... i need an amp that will do at least 1600 watts at 2 ohm... i believe the wcc amp is 2500@1 ohm.. not sure about 2 ohm though...
Username: Themax99se
Post Number: 17
Model Number 2500D
Max Power 2500
4 Ohm Rating 1200 x 1
2 Ohm Rating 1700 x 1
1 Ohm Rating 2500 x 1
Mono Rating -
Freq. Resp. 20Hz - 300Hz
THD+N < 0.9%
Damping factor > 50
Signal to noise ratio > 80
Crossover range/scope LP 30 - 250hz
12/24 db octave
WCC Amp:
Input sensitivity 200mV - 5V
Safe load impedance 1 ohm
Equalization Circuit Intelli Q
10 db
Remote level control Optional
Amplifier protection* T,D,R,S,O
Externally Bridgeable No
Dimensions** 27.2"L x 10.5"W x 2.3"H
Wow the HIFONICS BXi1606D amp dropped in PRICE! I have one of these to Two Type R 12's. Its not bad.
Username: Skies
Post Number: 105
oh haha..duh..sorry guys, thanks
Username: Ziemer_07
http://www.etronics.com/product.asp?stk_code=blibza2660&store=&catid=8052
hope this helps^^^...idk what u want tho like..what brand?,how many channels? how many ohms do u need? and for $400 u can get a pretty damn good amp...if the amp i sent wont work just go to etronics.com... n u can pick how many channels and wattage...and they have Really low prices!
