Arsenal 15"
Username: Kingjames
OH USA
Post Number: 161
hey watsup i was thinking of getting a 15 inch arsenal, do u guys think a kikcer kx 600.1 would push it okay?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2244
i think the KX amps are rated at 1 ohm. the Arsenals are Dual 4 ohm, so you can only wire at 2 or 8. the new ZX amps are rated at 2 ohms and would be a better match for you.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1806
you could look into a zx750.1 it would push a arsenal perfectly.
Username: Sw9152
Michigan
Post Number: 735
or an a8000t if you want to go cheap...
Username: Iufan4lifeul
Post Number: 1070
KX are rated at 2 ohm. That amp would push that Arsenal PERFECT.
Amplifier Type: Mono
RMS Power @ 4 Ohms: 300W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: n/a
Bridged RMS Power @ 4 Ohms: 600W x 1 @ 2 ohms
Speaker Level Inputs: no
Preamp Outputs : yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 20-200 Hz
Signal to Noise Ratio: >95 dB
Fuse Rating: n/a
(From cardomain.com)
Username: Kingjames
OH USA
Post Number: 162
but if i already ordered it would it push it okay, i got the idea from someone else on here, forget his name though
Username: Sw9152
Michigan
Post Number: 739
the kx600.1 should work fine, i dont know what brandon is talking about
"i think the KX amps are rated at 1 ohm"
the kx600.1 are rated at 600wrms @ 2 ohms and typically have a birth sheet that says the will put out over 700. the kx600.1 should push the arsenal great.
Username: Kingjames
OH USA
Post Number: 163
how should i wire it? i know they have a website on how to wire at diff ohms but since i have no wiring experince id like someone to give me an opinion, thnaks
Username: Nnnnick_b
Weddington, Nc Usa
Post Number: 753
I have owned 2 kx600.1's and both put out over 725 watts. Great amps.
Username: Six
Flint, MI U.S.A.
Post Number: 498
Arsenals perform spectacularly with anything from 500~1000 rms each. I had 2 powered by my SS 1000.2 in dual 2.5 sealed and they loved it... I also put both in a 7cuft box tuned to 28 hz and... damn. I loved it to death... It was the Killed SQL system... till someone jacked my sh!t. Now, my Viper 791xv protects my Monte'...
Stockbridge, GA USA
Post Number: 2255
Sw9152 - "i think..."
the KX1200.1 is rated at 1 ohm, but the 2500.1 and lower models are rated at 2 ohms...i'd of figured they were all the same. the KX1200.1 is the most commonly suggested of the KX lineup too, so thats what i was familiar with.
