MRD - M605 for 10W7-3?
Username: Brycew7
B.C., B.C.
I have a 10W7 in a ported box to JL specs, and i have a alpine mrd-m605 amp to power it ( 400W x1 @ 4 ohms, 600W x1 @ 2 ohms) will this amp be sufficient to get the W7 bumpin?? I have had ppl tell me that to get the 10W7 really bumpin that i need something like the 1000/1 or something similiar.
Username: Brycew7
B.C., B.C.
and also does this mean that my amp will be giving the 10W7 500 Watts @3 ohms??
Username: Gage
Post Number: 287
umm idk about the whole 3ohms thing lol but the 10w7 is rated at 500rms so yeah it would work pretty good but not sure how you would wire it id ask rovin someone else on here about that
Username: Brycew7
B.C., B.C.
Post Number: 7
well it's a 3 ohm single voice coil sub, and a 1 channel amp , so wiring is no problem.
Username: Langless28
Boston, MA
Post Number: 579
alpine's amps are rated at 14.4 volts. just keep that in mind.
Username: Adddisorder
West palm, Florida
Post Number: 262
because they are rated at 14.4 volts what rms do you think theyll produce seeing 12.5-13.5 volts on a stock alt.?
Username: Brycew7
B.C., B.C.
Post Number: 15
400-500 watts probably won't be enough to see it's full potential, that's what i thought , i heard the 10W7 on the 1000Watt alpine amp at a store, and it could've used a lot more juice i was thinking.
