Need subwoofer suggestion...
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 107
ok i have a mercury 2000 cougar, i measured it and it is about 36 inches wide and about 22 inches high, so i was wondering what sub i should get to put in it, i just had an orion 1200d running on my alternator adn lights were dimming, so i sort of want to only run like 800 watts on my car, i was thinking abotu 2 cvrs, or 1 15 inch subwoofer, so really my question is, if i was to get a 15, what woudl be a good one that take about 800 rms at 2 ohms, because im thinkin of just getting the A8000T, im more into spl than sq, but a little sq won't hurt...thanks
Username: Johammbass
Cork, Cork Ireland
Post Number: 167
Just get 2x12", each 400W RMS. It's way better than 1x15":-)
Username: Sw9152
Michigan
Post Number: 726
get one 15" cvx, you would be underpowering a little with the audiobahn though.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1798
maybe a AA arsenal, would be close spl wise with the kicker but would probally dominate it sq wise.
