Burnt VC
Username: Skies
Courtenay, British Colu... Canada
Post Number: 90
I was playing around with wiring configurations, and I figured I'd try a 1 ohm load with the 2 L5's(DVC4).. I've had this amp down to roughly .5ohm and its fine, and when I hooked up with kickers in parallel, basically nothing happens, there is VERY little sound, so I turned it up as I watched the subs... I took a quick look at the amp to see if it was clipping, and it was solid red and then the subs started making bass for a sec so I turned it down and then I saw the smoke...
Only one of the subs' VC burned though, I have the other one hooked up to 8 ohm right now and its fine...
Anyone know why they dont play when wired to 2 Ohm/Parallel?
Username: Lexuscoop
Pheonix, Arizona USA
Post Number: 237
they burned when you hooked them up to a 1 ohm load? what was the amp? thats wierd
Username: Skies
Post Number: 91
crown xls-602...
they've always been powered with this amp with no problems...
I've had 6 subs hooked up to this amp in parallel and it doesnt even get warm, I don't understand why it does this now....
Username: Lexuscoop
Post Number: 240
take off the heat cover and look at all the parts, something might be lose or something along those lines. there could have been something wrong with the sub to begine with, it could have had a loose wire, and that amp just knocked it off and blew the sub
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 479
ISNT THT A GUITAR AMP?????
Username: Skies
Post Number: 93
no its a commercial amp... used in concerts and such
Username: Skies
Post Number: 94
Thanks Shaine I'll try that later
Username: Lexuscoop
Post Number: 245
wow... someone took my advice LOL
