Rounded pvc resin box courners?
Username: Terry6405
Sullivan, IN US
Post Number: 778
how would i go about rounding the corners of my box? can i do it even though its laready built?
here is what i was thinking from what ive gathered
i will hot glue 2" PVC that its cut in half (a round corner)in all the corners i desire in my box (probly just the back wall because thats where i see it most cutial), the use painters tape in a couple layers over the PVC, now here is where i dont know what to do. do i just paint the resin/hardening mix right on the paint? or would i have to use some cloth or fiber glass? and how do i get it down to be smooth? and then do i just pain the inside of the box with the mix to make it smooth? i build a pretty good enclosure already and now i just want to make it as good as posible because i have time and $$ before my HU comes and i can acutally intall my box.
thanks
