For anyone thats confused about going sealed or ported...
Username: Suleman36
Maryland U.S.A.
Post Number: 3651
For anyone confused why they should go ported or sealed with your subwoofer....
ok first, you need to determine what the speakers are made for.. not all drivers work in both box types.
you need the TS stats.Should come with the subs, or download the tech specs from their website)
and calculate the EBP
here's how:
Efficiency Bandwidth Product (EBP)
EBP = Fs / Qes
50 or less = best used in a sealed enclosure.
50 - 90 = flexible enclosure options.
90 or greater = best used in ported enclosure.
very simple calculation.
Username: Rovin
Trinidad & T...
Post Number: 7662
nice ! ^^^- i usually send ppl 2 go read www.bcae1.com or http://www.diysubwoofers.org/ - lol ....
Username: Suleman36
Maryland U.S.A.
Post Number: 3652
I figured i should shed some light about this because alot of people are not sure. This way you get the best performance out of your sub and match it up right.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6833
make sure this thread never dies.. GREAT IDEA!!!!
Username: Mtite_dabeast
Post Number: 31
This page has been added to my favorites. Thanks!
Username: Terry6405
Sullivan, IN US
Post Number: 718
any similar ones for tuning frequency suggestions?
Username: Suleman36
Maryland U.S.A.
Post Number: 3654
Not really, just make sure you tune it above the FS aka resonant freq of the sub.
Usually between 28-35 hz for most SQ - SQL setups.
