I'm looking for some good speakers
Username: Don_beeski
Bourbonnais, IL Kankakee
Post Number: 69
I need som good 6x8" for the front and back of my ride. price range from 50-100. I already have 2 12" cvx subs so i need something that will sound good with them. Is it better to go 3-way, 2-way, or component.
Username: Adddisorder
West palm, Florida
Post Number: 178
what you should do it make a baffel out of wood to cover your fron 6x8 spot in your doors and cut out a 6.5 circle in it and put in some components then dont bother with speakers in the back for now because you wont really need them. youll need to run the comps. off an amp for them to really sound good.
as for 2 3 4 way is just really a marketing trick and doesnt really matter...
