2 batterys
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 188
how do u ho0k 2 batterys up in a car can u just run ur power wire from the stock battery upfront an run a thick gauge wire 2 the trunk an put it 2 the + an just ground the - ?
Username: B101
Queen City, NC USA
Post Number: 2290
yes :-)
That would be puttin both batteries in parallel, so u will keep a 12volt system....
Username: Andysd03
Post Number: 47
you would need a battery isolater it charges one battery at a time then would charge the other when the others one done otherwise the alternator would have to charge 2 batteries at once and that might be a tough task for it
Los Angeles, CA USA
Post Number: 3614
how about if you have a ho alt? i think with a ho alt you can just have 2-3 batteries without an isolator
Username: Andysd03
Post Number: 48
goto a car shop and ask the guy that to be sure say i got a ho alternator would i still need a isolator for 2 to 3 batteries see what he says i would think u would still need the isolator but ask to make sure
Username: Sw9152
Michigan
Post Number: 331
i have been running 2 batts for about a month on a stock alt with no problems...
Username: J_baby15
Kentucky
Post Number: 55
Same here...I just added a red top Optima in paralell wit my other battery and havent had any problems. Make sure you get a nice size wire to do all this, and make sure you have a good ground.
Username: Jmloughrey
Farmington, CT
Post Number: 1485
If you spent the money on a HO alt you obvisouly didnt spend enough if you need another battery.
The purpose of a HO alt would be to eliminate the need for extra batteries and such.
A battery is only going to help you if your playing the stereo when the cars off.
