2 15 sx
Username: Scott_debaker
Pittsburgh, P.A. U.S.A.
Post Number: 183
so if i buy 2 15 sx an put them in a 5cuft box tuned @ 30hz an both of boxes r in my back seat with both 15s @ the bottom an ports up by my head in a 1994 grand am both straped wit a kicker 1200 will it pound cause i put 2 jl w3s in the back seat an it was @$$$$$$$$$$ cause ill have myb $800 an 2 15s will b like 300 a pieace an i might get 1 kicker 1200 for like $200 so if i do buy 2 will it b loud in the back seat or if i face the subs 2 the roof cause i build my boi a box for his 2 12 cvrs an runnin off a boss amp an for sum reason that boss amp pounds i dunno y but it puts out more watts on 1 channel than a kennwood 600 but it pounds harddddddd need 2 take him out wit the rest lol
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 697
You shouldn't a 1200 watt amp with 2 1000 watt rms subs. That would be a bad setup. Get 1 powerful sub, and 1 amp to match it. Or 2 less powerful subs. Se 15's would match perfectly with that map.
Post Number: 184
u can use a 1200 watt amp on the sx every 1 here does they use re 12.1 kicker 1200 orion 1200 an jbl 1200 they put out atlease 1,400true an it wount hurt the sub casue the sub is underrated right guyz
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 698
I was saying it wouldn't be good on 2 sx's. 1 sx and 1 1200 watt amp would be great.
Post Number: 185
no i was sayin i can get 1 kicker 1200 for like 200 but i was goin 2 buy 2 any ways casue i was goin 2 have 1 on each sub
Username: Safe_cracker
Chicago, IL US
Post Number: 759
5cf is good for one sx15 not two. Polo..
Post Number: 186
no 2 5cuft slot ported boxes tuned @ 30hz 1 box for each an 1 kicker 1200 4 each but how will the subs sound in the back seat iam takin the seat out an the box will b like 34inches from the front seats to the rear 21 inches high an 16inches wide how will the subs sound facin up toward the roof a go0d 2ft away an both subs in the back of the rear n ports right behind the front seat will the subs sound go0d inside the cabin an both boxes 2geather will b 34d 21h 32w
Username: Alex_f
Lawrenceburg, Ky Us
Post Number: 700
well, with 10 ft2 and 2 sx's, and 2400 watts, No matter where they are, they will get damn loud. Dont foget about the alternator.
Post Number: 187
ya i no all that sh1t lol but i got 4g wire now an i dont know if i can run 2 1200 amps off 4g ill just buy sum 0g wire later on
