New member Username: SmokePost Number: 1 Registered: Apr-06 | i got 2 sony explodes 12inch.. and they are currently being powered by a powerbank amp.. 1000.2.. i never heard of this amp before.. the sony's are 350rms each.. i also have a 600.1 kicker powereing a jl audio w3.. it seems that the powerbank is not hitting at all compared the the JL.. do i need a better amp. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 360 Registered: Dec-05 | can you sell your subs? they're really bad! sell the powerbank if you want too then buy another jlw3 and wire them to the kicker amp. |
Silver Member Username: TitanbkMansfield, CT USA Post Number: 103 Registered: Sep-05 | Take a car battery, positive and negative cables,hook the cables to the xplodes and touch the wires to the battery till they start smokin. That should take care of the whole problem. |
Bronze Member Username: TonPost Number: 50 Registered: Jul-05 | do what juliob said. |
Silver Member Username: JuliobSanto DomingoDominican Re... Post Number: 367 Registered: Dec-05 | aruman= very smart guy |
New member Username: SmokePost Number: 3 Registered: Apr-06 | can my kicker amp really power tow jlw3? |
Gold Member Username: RzarectorCoquitlam, Bc Canada Post Number: 1045 Registered: Dec-04 | should, if u match the optimum ohm load for the amp.. it gives off 600 watts at 2 ohms no? so you need 2 dvc 2ohm jls and wire them like so http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2 |
