Final choice of 4 subs plz help
Username: Vc23
Post Number: 31
06 re xxx 15', jl 12w7, eclipse ti, alpine type x? going for all around sq and spl.
Username: Matt12490
Benicia, California USA
Post Number: 695
wait you want 4 subs?
Username: Ctmike
Ct.
Post Number: 243
depends on your budget but i'd go:
xxx
w7
ti
type x
Username: Redliner
Wilmington, Ma
Post Number: 1337
i fully agree ^^^ unless you have space issues then i would drop the xxx fromt hat list
Username: Matt12490
Post Number: 696
^^^^^X2
Username: Vc23
Post Number: 32
no i only want 1 sub and im puttin it in an explorer so space isn't an issue, but yeah when is the 15 xxx comin out? thanks alot for your advice tho
Username: Ctmike
Ct.
Post Number: 246
i'm not certain but i think you might be able to preorder it now.
Username: Vc23
Post Number: 33
any idea how much?
Username: Ctmike
Ct.
Post Number: 248
nope. i think i read a while back on another thread someone had gotten there xxx 12" and it was $630 shipped.
Username: Vc23
Post Number: 34
ahh ic thanks alot
Username: Vc23
Post Number: 35
you think the 12 or the 15 would be better for rap music and being heard from a ways away? or which one
Username: Ctmike
Ct.
Post Number: 249
if i had the money and room, i'd go for the 15". just remember that the bigger sub the more $ on amps to.
and have you upgraded your alt. yet? you're going to need to.
Username: Vc23
Post Number: 37
yeah i planned on gettin a orion 2500d and yes i planned on upgrading my alt
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 6465
Crystal Comp X>w7,ti,and type x
Username: Ctmike
Ct.
Post Number: 250
didn't think of that one.
what would you compare the comp to chauncey? i was thinking of getting 2 w6 since i can get a deal on them, but would the comp's be a better choice? looking for sql, but get really loud when i need it to.
Post Number: 6467
The compx=05 xxx (roughly) and they sell them on realm of excursion
Post Number: 6468
the compx has better sq, not sure about spl i only heard it with a jbl 1200.1 so it was not fully powered.
Username: Pelona
Perris, California USA
Post Number: 1328
how would u compare the comp x with an si mag chauncey?
Post Number: 6478
havent heard a mag yet
Username: Pelona
Post Number: 1333
i know alters heard them
Username: Sw9152
Michigan
Post Number: 347
vcs3 i got an explorer too and i have 15 eclipse ti in it and it pounds. if money isn't an issue i would get the xxx. i think the 15 eclipse ti is the best for your money on your list. $380 new from electronicgiant.com, the 15 xxx will prolly be 650+. the W7 would be more expensive too and would get near as loud unless you dumped a bunch of money into a ho box. the type x is almost in a different catagory than the other subs don't get it.
