Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3501 Registered: Feb-05 | Hey jonathan, i have a box laying around the house that was for a Avalanche 15 sub. Its 2.2 cuft sealed enclosure. Whould a 15w3v2 work well with the enclosure i have ? I have 900 watts from that arc amp. Will i be ok if i ran it to this sub sealed ? If i kept my gain low. here is the pdf for the 15w3v2 http://mobile.jlaudio.com/pdfs/8032.pdf |
Gold Member Username: James1115Ct Post Number: 5564 Registered: Dec-04 | that is a lot of power for that sub MO. That enclosure will work nicely though. |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3502 Registered: Feb-05 | I know man, i need to either sell the box or do somthing with it since i dont have a subwoofer right now. It gets boring after a while without one. Maybe i can find a decent 400 watt rms amp for it. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 6445 Registered: Jul-05 | how much for the box??? |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3504 Registered: Feb-05 | $160 shipped |
Gold Member Username: James1115Ct Post Number: 5570 Registered: Dec-04 | thats a good deal |
Gold Member Username: James1115Ct Post Number: 5571 Registered: Dec-04 | what are the dimensions Mo? |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3505 Registered: Feb-05 | 29 1/2"L x 17H x 11"D, Vented Bracing, Charcoal Grey Carpet, Terminal Cup, 3/4" MDF |
Gold Member Username: Suleman36Maryland U.S.A. Post Number: 3509 Registered: Feb-05 | Im thinking of a 15w3v2 off a Phoenix Gold X400.1 Let me know what you all think cause i have never personally used these amps but i here some good things about it like it being 400 rms from 1-4 ohm like the jl slash and it even has a built in fan etc... http://www.cardomain.com/item/PHOX4001 |
