Sub and amp= 600 dollars
Username: Jkidder
Spring hill, Florida Usa
Post Number: 79
my friend is looking for a sub and amp combo n' has 600 to spend. he really wants good good SQ but an SQL system because he needs some bass too.. i was thinking some subs would be ID MAX, SI MAG, or anything around 1200 rms so he wont need to upgrade his alternator.. we were also thinking about the elemental designs ED nine.1..he currently has an eclipse set-up and is looking for a new sound. he has a tiburon.. any help or suggestions would be greatly appreciated
Username: Erikdagenerik
Livermore, CA US
Post Number: 57
IDMax 12" V3 w/ Hifonics Brutus BX-1000D will cost you around $500ish not including shipping. Use the spare money and get yourself a nice professionally made box.
My friend just bought an eD 13Ov2, sounds good, but doesn't hit as hard. It's not always about wattage though. Some subs are more efficient than others.
Username: Alteraudiousa
Concord
Post Number: 589
I would get a Soundsplinter RL-p with a USAmp Merlin MD2 which I can get you. I think it would cost a little over 550$.
Username: Jkidder
Post Number: 80
would that amp be to much on a stock electrical system? it says 2000 rms @ 1 ohm? is that correct?
Username: Jkidder
Post Number: 81
bump
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 80
kicker 15 inch L7 and a hifonics brutus mono 1500 watt 1 ohm stable amp from woofersetc.com just over 600 bucks
Username: Matt12490
Benicia, California USA
Post Number: 683
dont listen to him^^ that would be the opposite of SQ
Iowa City, Iowa
Post Number: 81
it says sql also
Username: Rovin
Trinidad & T...
Post Number: 7273
1 12" Idmax 2ohms dvc version ($320) & 1 MB Quart RAA1000 amp (around $260 now) ....
Username: Redliner
Wilmington, Ma
Post Number: 1311
"it says sql also" yes but it doesnt say I hate sq because thats what the l7 is a sub that has no sq and sql also means they want it to sound good newb. and for whoever said mag not to be mean but theres no way he can get that witht the budget there they cost up around 500 a piece i would go with rovins pick or maybe some type r's
