Parking brake lockout
Username: Buddyleee5
Post Number: 180
i have a clarion vrx765vd in a 2003 lincoln ls. I got it professionally installed so they had to ground the video to the parking brake.how do i remove this from the parking brake so that i can ground it to the chassis and watch movies while driving?
Username: Langless28
Boston, MA
Post Number: 489
look for newely placed wire somewhere round your parking brake. hopefully it will be for the deck and screw it to the chassie.
Username: Ironslave
Offutt AFB, Nebraska U.S.A.
Post Number: 400
the wire is "Grass green"
and it goes to your Parking brake light.... one way to get around it is to press on the P. brake until it turns on the light... if there is no resistance than drive like that...
Post Number: 181
i have an automatci tranny and i just was wondering how do i get to the wire? i dont know hat to open to get to the wire
Username: Six
Flint, MI U.S.A.
Post Number: 487
I have a VRX925VD. When I first installed it I didn't hook the grassgreen wire up to anything. Just snip it before it goes to you Parking brake and tapp it into one of the 2 black ground wires, and Presto! Moves while drving :D
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1005
how brilliant is that.. watching amovie while you drive, have fun crashing
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 833
haha yeah its pretty dangerous. theres been several times that i had to slam on the breaks before rear ending some chick.
like everyone said, undo the green wire and its on.
Post Number: 184
how do i get to the wire though? where do i cut it?
Username: Six
Flint, MI U.S.A.
Post Number: 490
Anywhere before it gets to the brain... and just tap it into the black...
Username: B101
Queen City, NC USA
Post Number: 2245
just ground the green wire, I think is what he is saying.. :-) if its smart it may be a + or - trigger :-)
Post Number: 185
the vrx 765 doesnt have a brain its an all in one unit. and ive read aout it and it says to do it all i have to do is groud it to the chassis. i was just wondering what i have to open up to get to the wire so that i can groud it to the chassis.
Username: Six
Flint, MI U.S.A.
Post Number: 493
I'm sure there is bare metal behind your radio somewhere... Just make sure you havea good connection and you're set... :-)
