Could someone give me some advice?
Username: Quadforce
Hi, I have 2 15" Bostwick HD-Pro's and a bandpass box and im not sure what amp i need to power them.... the speakers specs are
Diameter: 15
Frequency Response: 20-120 Hz
Sensitivity: 89.32 dB
Impedance: 4 or 8 ohm
Voice Coil: Single
Power Handling: 150-350 watts
Xmax:
Sealed Enclosure Range:1.5-1.9 FT3
or you can see them here...
http://www.bostwick.com/spec/subwoofers.asp?gID=%7B6F2B7AE6%2DA7FD%2D4215%2DA776 %2DAECBCC0776D1%7D&P=HDPro+15
My box is A bandpass with 4 ports and cab be seen here...
http://www.boomboxdepot.com/BP-15a.jpg
any advice on what amp would best suit me?
Thanks alot
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2567
JBL BP600.1
Username: Quadforce
Anyone else? I would like to hear from a few ppl and then make a desicion..
Username: Glasswolf
Post Number: 2575
Kicker KX600.1
or any good sub amp rated for 600wRMS x 1 @ 2 ohms if you have two 4 ohm subs.
Username: Quadforce
OK, which of those 2 would you recomend the most? or does it really matter?
Username: Quadforce
GlassWolf, In another post you told someone If they went with a ported box
"go to partsexpress.com, and buy $20 FMOD 20Hz high-pass subsonic filters for the amp to prevent over-extension from the subs.
also grab a couple Y splitters to send signal to all 4 of the JBL's RCA inputs.
makes for a stronger signal to the amp and better output" Is this something i should do aswell?
Username: Quadforce
ok , where might i be able to buy a JBL BP600.1 ? jbl says they are discontinued
Username: Vipersbyms
Post Number: 78
sounddomain.com has them for $220.
just search for them and you should be able to find many online stores that carry that amp.
Username: Glasswolf
Post Number: 2585
if you get the JBL and use a ported box, yes you want that fmod subsonic filter, and the Y splitters. (the Y splitters regardless of box type)
between the two amps, I'd get teh Kicker.
nicer amp in general, has the subsonic filter built in already.. it will cost more though.
Both however, are good amps.
Username: Quadforce
thanks for all your help Glass, one last question... How should i hook the speakers to the amp? ive heard of parallel but not sure what it means
Username: Glasswolf
Post Number: 2596
simple
the JBL has two sets of speaker terminals to make the job simple.
wire one sub to each set of terminals.
all done.
Username: Quadforce
Post Number: 7
well... i was gonna get the kicker though :P so how would that go..?
Username: Glasswolf
Post Number: 2604
same idea
just wire both subs straight to the amp
the manual has pictures.
its really simple.
you'll see what you
re ready to wire it all
