Can you recomend and tell me a good set up
Username: Extrmndor3
Chicago, Ill Us
wat up i have two aduiobahn aw12o6t flame q's and two sony xplod p5 amps i know all of you said that audiobahn sucks including sony but i limited in budget i just made a custom box is a 6 cubic ft per chamber can those subs handle all that space and im thinking upgrading my amps im thinking the precision power 1000.1 but theres one for sale but is refurbished can you tell me also about the refurbished thing and can you recomend and amp to hit the most db's as posibles but not to expensive, and finally wath you thing if this set up works and if not what subs you recomend to hit the most db's at a medium price thanks boys
Username: Greeney1888
Maple Grove, MN United States
Post Number: 163
whats ur budget?
Username: Eeater
Post Number: 76
Try http://www.ikesound.com/ they have waranty protection on refurbs!!
Chicago, Ill Us
around 500 bucks
Chicago, Ill Us
so wath u think about the aduiobahn with the precicion power
Chicago, Ill Us
have u check or heard the 12 assasins wath if i get 4 assasins in a 12 cubic ft box with two amps each running at 400watts at 2 ohms each so it will be 800 watts total and if u know much about db how a proximatly can i do with this set up thanks
