Jl 1000/1 question
it says the amp puts out its rated power at 11 or 14.4 volts. my lights blink like crazy and i only have stock 130 amp alt. and stock batt. would i even benefit from getting a big batt. since it puts out its rated power at low voltage?
Username: James1115
Ct
Post Number: 5118
your problem is that your alternator only puts out 130 amps at like 3500 rpm. at 1000 rpm it prob puts out 90-100. That amp at full power will draw close to 100 amps. The only way around this is to upgrade your alternator to one that has more output at idle.
Username: Judgedredd
Post Number: 11
Following James advice, you could install a smaller pulley on the alternator..however..with the amperage you're talking about, a better battery and a capacitor should fix the problem too...although I'm not a big fan of caps anyway
Username: N2audio
Lawrence, Ks USA
Post Number: 611
my guess would be an installation problem. 130A is a lot of alt. If the 1000/1 is your only amp you should be able to run it with no problems at all. Have a parts store check your battery.
What size power/ground wires are you using for the amp?
